What can I use to thin scalecoat paints.
Scalecoat thinner works well [;)]
Be sure to use the right one for the type of Scalecoat you are using…Scalecoat I or II. Although I’ve used I thinner wirh II paint and nothing bad happened. I think the I or II thing has more to do with the material you are painting.
I’ve also used plain old paint thinner from a hardware store to clean Scalecoat out of my airbrush and paint brushes.
I use mineral spirits…works well.
Mark H
Have you visited the Weaver Model’s Scalecoat page? Maybe you will find some tips there?
http://www.weavermodels.com/page12.html
Good Luck, Ed
Another option:
I’ve been using Klean-Strip Lacquer thinner for the past 2 years with Scalecoat II paint and have had good results.
In the photo the car has Scale Coat 2 paint that was thinned with the Klean Strip thinner. The finish was very smooth and wet in appearance. Klean strip is available at many hardware stores and home depot.
http://www.homedepot.com/p/Klean-Strip-1-Pint-Lacquer-Thinner-PA12782/203713864
I’ve thinned it as well using hardware store brand laquer thinners. Really didn’t see much difference in the resulting finish - plus, it dried a whole lot faster !
Mark.
