Is there a complete or almost complete list of all Scales starting with live steam?
I realize most of the common scales but get very confused when subscales are referred to and just what size track that these scales run on. For instance does O scale run on 3 rail or two rail do some O scale loco’s run on HO scale track? Just how many n designations are there ie HOn3 On30 etc.
It would be nice to have a complete list of each scale and subscale and what size track that they would run on.
This is called On30 by most of the real world except for the folks at MR, for some unknown reason. Bachmann is one of the largest suppliers of On30 equipment, although there are others. It is scaled to be able to run on HO scale track, although there is correct track available. Many convert HO scale mechanisms to On30.
This is true that I cannot attest to the accuracy of the list. It was just a list I had found when I was looking. I think with the list as a starting block and everyone’s input we may end up with a good list once all is said and done.
I have some problems with that list. For starters, it isn’t arranged in a very uniform order, either by scale or by gauge.
But further, and most annoying to me,[soapbox] is that it doesn’t make clear the difference between scale and gauge. The worst offender in this regard is the reference to “G Scale”. G is not a scale - it is a gauge. Specifically, 1.77" between the rails. There are a number of scales (the size ratio) that run on G gauge track, ranging from 1:20.3 to 1:32 in size. As can (with difficulty) be determined from the list, the G Gauge is also (and was originally) named “Gauge 1”. Our “O-gauge” was originally “Gauge 0” (zero), the next step down from Gauge 1. They need to keep in mind, that the gauge is merely the distance between the rails, and has only incidental connection to the scale of the models being run on it.
[end rant]
The list does indeed have some wierd scales/gauges listed, the vast majority of which are no longer (if they were ever) used.
What I tried to do is get a list of the scales that are known and what size track that is used to run them on. This list and the additions to it a great way to find this info out. There are so many different scales and it is hard to know what scale runs on what gauge track. I didn’t know live steam isn’t a gauge or that G is a gauge. I always thought that G stood for Garden rail.
