My wife bought me this Scanner radio yesterday for our anniversary, it’s pretty cool, it’s a Uniden Bearcat BC125AT, now my question, Since I’m new to Scanner radios I thought I’d hear consent chatter but so far, dead air, is there something I’m missing?? I get NOAA radio no problem, I’m a weather geek, but I’m also a railroad Nutt lol,
Programming Custom Search Ranges You can define each search range used during a Custom Search. 1. Press Func then Pgm/E in Custom Search mode to view the Search menu. 2. Turn SCROll CONTROl to Program Limits and press Pgm/E. 3. Turn SCROll CONTROl to Search Bank 1-10 and press Pgm/E. You will see the previously programmed lower frequency. At Lower, press Pgm/E and use the keypad to enter the lower limit frequency then press Pgm/E. 4. Scroll to Upper and press Pgm/E. You will see the previously programmed upper frequency. Use the keypad to enter the upper limit frequency then press Pgm/E. 55 5. Press . Clr to return to the Select Bank menu. Repeat for each custom search bank you want to reprogram then press Srch/Svc to start searching.
Set the scan range to scan from 160MHz to 161MHZ, you will only receive RR transmissions.
The SP radio tech working out of Bakersfield retired several years ago so no recent contact but he said he didn’t know of any plans for the UPSP or BNSF going digital.
If you’re going to use it in your car, you may want to check out your state’s laws. Some states discourage scanner use in vehicles, since it has been used to try to elude the police or highway patrol while speeding. I know here in MN, you can have one in your car but have to get a license for it - the license is easy to get and inexpensive, but you can be ticketed and fined for operating a scanner in your car without one.
I got a hold of the tech that replaced my friend and he told me the UPSP and the BNSF have been NXDN digital locally for two years. He said they sill do analog on the road. The NXDN radios are dual mode, analog or digital. I retired in 2007 so I’ve been out of communications for awhile, this is the first inquire into communications since I retired.
After working in two way radio communications for 49 years and 10 months when I retired I tossed everything even resembling a two way radio.
You’ve got the appropriate local channels to monitor programmed in right? (I’ve been involved with tech support, I always ask the dumb obvious question first. )
Depending on where you are, yeah, it can be pretty quiet for long periods. It’s definitely not constant communication.
Amount of traffic will obviously affect things, as if there’s nothing within 50 miles of you, you’re not likely to hear any chatter. Type of operation as well; CTC most of the “dispatching” is done via the signals, so there’s very little direct radio communication between trains and dispatcher except on leaving an initial yard where the crew calls the dispatcher and tells them they’re ready for signals to get going.
Track warrants or similar type of operating systems are much more “chatty” with formal instructions given directly via radio.
If there’s a large yard terminal with multiple active switch jobs there will be lots of local chatter, but if you’re on a cross-country mainline in the prairies away from a large yard, there will be much less chatter.
All good advice. What will really help is to get the local channels prograammed in so you can scan just them, Scanning the entire band will find good freqs, but can take some time, so better to have a good selection of what you know will work. How to find that out? Go to RadioReference.com and look up your state’s RR freqs, like here:
Hi Graham line, I live in Tigard, I’m about a mile and a half from the OE dist of the Portland & Western, and about 9 miles from UP Albina yard, so I should be fine.
