hello i 'm wrking on a shelf layout in the attic using hollow core doors supported with 2x4 arms screwed to 2x4 studs, the doors are 2 feet deep and i have 2 set up in an a “L” shape. At this point I’m trying to go as inexpensive as possible, bt still quality
the doors aren’t the flat surface ones so i used 5/8 osb from lowes screwed to the surface and then attached 1/4 foam board ( from the dollar store) I had painted the surface osb and while the paint was wet layed the foam on.
side note the bnch work so far has been inexpensive doors 3.00 a piece, osb 5.80 and 8.00 for foamboard
now the layout is going o be set in the susquehanna valley in north Central Pa, so the track is going to be flat with built up scenery like rolling hills , mountains and knolls
my previous layout i had more fiancial resources so i used 2’ foam to build up the scenery
I’m thinking aboutt a couple options including using CELOTEX to carve and build up hillsides and once it is shaped coveing it with some sort of plaster cloth then the normal ground covering techniques
I’m ooking at celotex because of the price, it seems i would get more material for the price.
has any one used his material before?
it won’tbe sed for laying track on etc
thanks for any tips
mark
top
