I am in the process of building a vertical lift bridge based upon the PRR bridge over the South Branch of the Chicago River in downtown Chicago. This is the prototype.
I began this project by building the bridge itself, using three Walthers Cornerstone Arched Pratt Truss Bridge kits, as detailed in the following forum thread.
Now, the challenge is to build the towers. They won’t be skewed like the prototype, but more rectangular like most vertical lift bridges. The main superstructure of the towers will be accomplished using Central Valley Model Works Heavy Laced Beam kits.
I will post my progress on this part of the project as I move along.
I will be using Central Valley Model Works Heavy Duty Laced Bridge Girders (#1900-5) to build the tower superstructures.
One of these kits contains 5 sprues, and each sprue contains 2 solid beams, 6 large X-braced beams and 3 small V-braced beams. Actually, these are half beams that need to be joined together to form a single finished beam.
I will be joining X-braced beam halves to solid beam halves to form the vertical and diagonal beams. I will be joining two x-braced beam halves together to form the horizontal beams and joining two V-braced beam halves together to form the horizontal cross supports.
So, in total, each kit will have enough parts to form 10 solid beams, 10 X-braced beams, and 10 V-braced beams. My estimate is that I will need 232 individual parts to build the two tower superstructures. So, that means that I will need to purchase 8 kits.
This will be tedious work because I need to paint the inside of each half beam before gluing the half beams together to form single finished beams. The insides of the joint beam halves need to be painted, since they will be visible through the lacings.
That is an easy scratch building project using Pastruct and/or Evergreen sturctural pieces. Try building an ore hullett. I did and it took me three months to build. I used the article in the October 1997 RMC. It is really a complicated beast.
You have already proven your bridge building skills so I’m looking forward to following your building of the towers. Great project!![tup][wow][yeah][tup][bow]
I am about to start building a bridge for the club which will be 83" long with an easement in the curve. The bridge starts with a Central Valley 200’ truss bridge and then uses an ME 85’ plate girder followed by a series of 30’ plate girder sections on the bents with 50’ plate girder bridges between the bents. I have never attempted anything like this before but having seen what modellers like you have done, I’m not worried that I can pull it off.
An easy scratch build project?? Ooh, that hurts. [swg]
I’ll tell ya what. Post some photos of your ore hulett for my needed inspiration. I would have no objection to you posting some photos on this thread. It would be fun and instructive to see them.
I have to say, building an 83" long bridge with an easement in the curve is going to be some kind of challenge. I hope you will post your progress on that project. That 83" long bridge will dwarf my 30" effort.
Actually Rich I think your project is much more challenging. The length of my bridge doesn’t really make it more complex. You are scratchbuilding. I am simply making some standard modifications to ME components. I think my project will be more tedious than difficult. I have to figure out the instructions for building the bents but once I have those down pat it will just be a process of repetition. I have to shorten the bents by about 1 1/4" so that will require some contemplating. The curve will be easy to duplicate because the plywood roadbed is already in place where the bridge will be. We are going to imprint the track position on a sheet of 1/2" rigid foam so it should be easy to mitre the deck girder bridges to match the curve.
Maybe I am being naive. It wouldn’t be the first time.
You will find it much easier to build those CV girders if You build a right angle jig, to hold them square and in place while glueing, I know I did. Also make sure You Read the instructions thoroughly, because they will give You tips on what to use to keep the lattice work even…drill bit sizes. I made my jig out of 1x2 pine and a 5/16ths square piece of pine screwed to the 1x2. Then just brushed a bead of adhesive down the seam, capillary action did the rest. I used Plastruct orange bottle.
After making the jig, I found many more uses for it.
I have made a template to faciltate building the towers.
What I simply did was to draw the contemplated dimensions and trace the parts needed to complete the face and rear portions of each tower on a Masonite board.
Then, I clamped wood strips to hold the parts in position. The trickiest part is forming the X-brace across each “box”. Gussets will hide imperfections in the fitting process.
I want to add one more vote in favor of posting progress photos, mainly for inspiration to others, but also out of curiosity and general interest. Ours is a visually intensive hobby.
Side note to OP Rich: glad you decided to ignore the skewed aspect of the prototype. No sense driving yourself nuts; plenty of other things to worry about. My goal is to try to capture the essence of the scene, and modifying reality to suit is not really a big deal.
Well, there is a submarine that’s been sitting dead at the curb in the basement of the Museum of Science and Industry. Could patch the extra holes they cut in it, hotwire it - common enough in Chicago - but getting it out of that hole would be a neat trick.
Rich is wise to make the piers non-skewed. The twin lift towers will still be tricky, as they must be both vertical and parallel. Is there a nice solid base to build on here yet to hold all in alignment, mount the drive mechanism on, etc? Then have the whole shebang drop into the location to then attach to the approaches?
I forgot they don’t have any tips on the ones You have. The ones I used do, 1902-5. I wound up getting all the ones they made for different projects. Used all kinds of sizes in the Rolling Lift Bridge bash:
One, I do not intend to make the lift operable. That bridge will just sit motionless on my layout.
Two, I have never fully understood why the engineers designed the towers to be skewed. True, the bridge crosses the river where it runs on an angle, but the towers still could have been built in non-skewed fashion. I believe that a skewed design was selected to avoid having to make the bridge longer (and heavier) if the towers were set further back on solid ground.
