Sealing Laser Printed Decals
Since Dullcote cannot be used to seal laser prined decals, what can be used. Maybe dilute white glue or maybe matt medium?
Thanks in advance,
Mark
Hi There There is a 1oz bottle of DECAL Film you Airbrush or hand brush over the decal paper after printing your art work ! You should let the decal paper cool first after printing on a laser ! I will get you the company name by Sunday
I know that Microscale sells a small bottle of Decal Film. I have used it and it works. The only problem I have experienced is that if you do not put it on very thin the decal might curl.
Thank you for the replies. But I am thinking about what to do after the decal is applied to the model??
Markie, forgive the slight diversion in the post, but what type of decal paper do you use? I tried making stickers with printer paper, but they don’t adhere with liquid glue.
I used laser printer decal paper that I purchased on ebay. Made and used decals with it before and they turned out to be pretty good. However, I installed them with no sealing and I’m concerned that eventually they will fail (as in start to peel).
Test Krylon Acrylic clear spray. It is what I use to seal my inkjet decals. Art supply stores like Michaels or AC Moore have it. It is available in gloss or matt finish; UV resistant is also available
http://www.michaels.com/krylon-acrylic-crystal-clear/10520106.html?productsource=PDPZ1
