Hello All,
How old is the track and what code; 100 or 83?
I have a new pack of HO code 100 Atlas super flex-track and each 36-inch section has 3 holes drilled (like 9-inch sectional) then four ties and then another set of holes.
There are 4 sets of these factory drilled holes per section.
If your particular track doesn’t have the starter holes on the underside there are a few options that haven’t been posted.
You can use a pin vise with a 1/16-inch drill bit to make your own holes.
You didn’t mention what your sub-roadbed is; foam, plywood, MDF, etc.
Cork roadbed is definitely more substantial than foam.
If you choose mechanical fasteners through the holes; track nails, track spikes, or brads, I would recommend brads.
These are more readily available at hardware and big-box stores, usually cheaper than the “specialty” fasteners, and available in a number of lengths to suit your particular needs.
I use #19 x 5/8-inch wire brads to hold the track in place after securing the roadbed to the sub-roadbed with an adhesive.
Then I ballast the track and remove the brads. The ballast is sufficient to hold the track to the roadbed (I use Woodland Scenics foam- -add snarky comments here).
Another option would be to use an adhesive (I prefer silicone caulk) and 2-inch “T” pins to hold the track in place while the adhesive cures.
For this method, you don’t necessarily need to drill holes in the ties.
You can simply use the “T” pins on the gage (inside) or field (outside) of the rails to hold the section in place while the adhesive dries.
- Pro tip: To prevent lifting of the track while drying place weights on the track- -soda or canned goods mak
