What would people recommend as a good, long lasting way to secure homasote to the decking of a permanent layout?
The last small layout I did was in the early 1990s. I glued the homasote down with Elmer’s wood glue, and then screwed the homasote to the decking in the corners. Years later the glue has held in most (but not all) the spots, but the screws are still very secure.
Just curious what those with more experience have found over time.
I just put my homasote down on Friday night. I used Liquid Nails, and then put a few screws around the edges to hold it down while it dried. It was rock solid by Saturday morning. I am going to leave the screws in just to be safe, but I am sure I could remove them without causing any problems. Good Luck.
If you know you won’t be taking it up, Liquid nails or some other construction adheasive is great, BUT, it’s not coming up. If you want to make changes, use screws to attach the homasote to the base. To maintain sound isolation, any screws you use to attach stuff to the Homasote should not penetrate down into the wood table top.
I would advise that constrution adhesive be spread flat and thin with a spatula…thoroughly. Because homasote has little shear strength, Beads of adhesive can cause mini hills and valleys on the homasote surface. This can lead to faulty trackwork.
I do not like spreading construction adhesive because it is rather thick and messy. Heating it to 125 degrees helps. I had no problems using Elmers type glue. I troweled it on thin, covering the entire surface and weighted it with books. No screws and nails were used.
I do not like using screws or nails. Screws or nails can cause the forementioned hills and valleys too as they concentrate pressure deforming the homasote. Also, murphys law states that track screws land where the homasote screw heads are.
Chuck is right about track screws. Don’t drive through the homasote and into the wood. You only defeat the purpose of homasote as they transmit noise.
I used Liquid Nails to glue the Homasote to the plywood and then screwed it down to pull the Homasote tight to the plywood. After two days, I removed the screws. The Liquid Nails will hold much better and longer than glue. I had read that removing the screws is recommended as not to transfer any unnecessary sound through the Homasote to the plywood. Wether that’s true or not i’m not sure, but I removed the screws anyway.
Chris: I use screws, mainly because I have found it easier to remove. (I am never satisfied with my layouts and enjoy just building new ones. I use the stuff over and over.) That being said, for a more permanent layout, adhesive is probably the way to go.
PS. Thanks for your E-Mail about passenger trains.
My all-purpose adhesive when I built my layout was the stuff used for glueing on vinyl baseboard. Comes in water or solvent based. I used a notched trowel the same as putting down a floor.
I used the Liquid Nails with 1/2 foam board. It set up within minutes and ready to use. Also used it to attach my LifeLike grass. Really like it. I attached the Fastrack with screws. Widend the holes just enough and sunk the screws injust enough so the track is held in, but “floats” so that the sound dosen’t transmit to the board.
I used Carpenters glue in the gallon jug and a paint roller. Screwed around the edges and removed when dry. I know homasote is paper based but the glue worked well.
I used Liquid Nails to glue my Homasote down this time. My first try was with Elmers and it worked OK but the moisture in it caused the plywood base to warp slightly and the Homasote to swell a little. When the glue dried it held that slight warping in place and nothing I did would flatten it.
Sounds like construction adhesive is the way to go. I figured it would cause slight hills and valleys knowing the consistency. I did not experience any warping with white glue but I did weight it down with books…every square inch.
I purchased the homasote yesterday. It was difficult to find. Several of the large chain hardware stores had no idea what I was talking about. One building supply place recently changed to ordering it on an as needed basis. I finally found a building supply place that had it in stock.
Went to a large chain hardware store last night to get insulation and some duct work (much farther from home) and what do I find… a stack of homasote.
Maybe it’s a corporate prank so the customer never knows where to find something. This way the customer eventually visits all the stores in the country.
Coming in here late, but I never gave it a thought to secure the homasote, (AKA, building board, sound board, brown board, and even as I noticed at a discount big box recently, pin cushion board), down to the plywood deck.
I’m at the beginning stages of building my layout, and I figured there would be enough wires, etc running through it to hold it down. I had also recently ripped a clear 1x6 with a slight bevel to wrap around the layout table for a finished edge. This was to hide the rough edges of the plywood and homasote, and 1x4’s. That addition of the trim board, with wires , etc., I hope will hold it in place.
