Hello All,
I’m in the finishing phase of my kitbashed Walthers Northern Light & Power kit- -two kits combined to make one large structure to cover the 5A booster.
The two kits I’m combining were manufactured with slightly different colored plastic. If one kit was assembled on its own all the components would color match.
Because I have combined two kits, with slight color variations, I rattle can painted the wall sections with the same color for uniformity.
I then custom blended acrylic paints to replicate the granite colored lintels. After masking I airbrushed these details.
As I was working on the interior walls of the kit I noticed that the acrylic paint on the lintels was being scraped off on the work surface, despite over two weeks of drying time.
On my paint rack, for a clear matte finish, there is:
- Krylon, Matte Finish; #1311
- Valspar, Project Perfect Top Coat Flat Matte Finish; #84237
- Valspar, Primer For Plastics; #68109
I chose the Krylon.
Using the “bain-mare” method I prepped the rattle can.
The only problem I had was the nozzle on the rattle can. Occasionally the spray would collect on the nozzle, form into a drop, and fall onto the wall section underneath.
Shaking the can frequently “cleared” the nozzle of this build-up.
Another option would have been spacing the wall panels farther apart on the painting rack. That would have prevented the unintentional drips from the nozzle falling on to the panel below.
The dry time was quick. This product sealed the acrylic paint to the underlying rattle can base.
Next step- -highlighting the mortar lines with joint compound.
Hopefully, an additional side-effect of the matte finish is it will give the joint compound something to “bite” into on the plastic kit.
Hope this helps.</
