Hello all - I’m probably 80% complete building my layout. It’s the John Armstrong Ho-29 (Central Midland) with just minor modifications and I’m using DCC. I do not have many of the track insulators that are in the original layout plan, as I’m not using DC cab control - just DCC. Here’s a link to the full layout plan: Central Midland track plan.jpg The track leading to the yard area and engine servicing is electrically isolated from the mainline. It is powered via Onguard OG-AR auto reverser.
Here is a link to a close-up of the problem area:
The problem I’m having is a short when a train exits the Wye on the right hand side of the images. I have track insulators on both rails at the locations with the yellow markings. The red markings are where there is one insulator, just on the right side of the track.
Here’s the odd part - the engine will use the “south” side of the Wye and enter/exit the mainline just fine.
But on the northern side of the Wye as soon as the engine bridges the insulators, it causes a short circuit, and track power is cut. IF I reverse the leads coming from the auto reverser, the engine will exit the NORTH side just fine, but cause a short when it attempts to exit the south side of the Wye.
Any ideas on what I need to insulate/modify to allow the engine to exit both legs of the Wye?
Just for grins, here are two pictures of the layout, just to add some color to how it looks.
Atlas turnouts? If they are a power routing turnout, I think you need one more gap at 6L on the other frog rail. If they are Atlas, no and I don’t know why that would only be a problem on the north end of the why.
I assumed he meant that both tracks have a shorting issue, but maybe I should not.
After rereading his post, I believe everything running left of the yellow marks and near or including that 19 degree crossing are controlled by the reverser.
The fact that his problem reverses N & S when he switches the leads is an important clue. Unfortunately my deer stalker hat is not to be found.
If he is referring to the crossing, I think it is a gapping problem, not a wiring problem. I drew up a couple of possibilities for effective gapping, but we need to hear from him first.
Thanks for the replies - I am refering to both “north” tracks as having the issue, the short occurs when the engine crosses the insulators (yellow in the track plan).
Yes, everything left of the yellow marks is a seperate power district, powered from the reverser. Although it’s not evident in the diagram, there is no “out” to that power district. The only connect to the mainline is through this wye that is in the track diagram above.
The turnouts are Atlas, each frog seems isolated, and not has a small plastic gap between the frog and the rails it leads to. I don’t have any wiritng to the frogs.
My confusion lies here - shouldn’t the auto-reverser be solving this?
I believe it should and your gaps look like they are in the right place to me. However the problem shouldn’t switch from North to South, when you reverse the leads. Yet it does. [:(]
Are there any other circuit breakers?
One pathway through the northern crossing is isolated on both ends. I suppose that means there are jumpers in the crossing to supply power. If there weren’t or if they were bad, the loco would still stall there when you reversed the reverser leads.
I took a look at the entire track plan. Those four turnouts coming off the mainline, to form a wye at the 19 degree crossing, lead to a stub end yard. So, the divergent end of each of those four turnouts needs to be gapped to isolate the entire stub end yard from the double track mainline. No other gaps are necessary. Everything to the left of those four pairs of gaps becomes the reversing section. Those other gaps (red and yellow) should not be there. The two wires coming from the output side of the OG-AR should connect to any and all feeders inside the reversing section. No feeders from the output side of the OG-AR should be connected outside of the reversing section.
Rich, I’ve following along, as you seem to figure this kind of stuff out, so it looked like a complicated enough of a layout for me to learn something.
I see the 2 turnouts and the 19 degree crossing, that make the “Y”, and to the left of that are 4 turn outs that make a cross over, is that where your talking?
Yeah, for awhile I was confused because there is a “wye” track inside that bottom loop. But, I now believe that the OP is referring to the 19 degree crossing and the two turnouts to the left of it that form a “wye”. I circled that area in red. Everything to the left of the red circle is part of a stub end yard.
Rich I’m lost too with all the crossings and double track. The turnouts all have numbers, and the routes through them labeled N&R
Are the crossings what is causing his problems? Otherwise, the diverging routes are gapped…eventurally.
Starting at the bottom right, 5 & 6 are gapped after the crossing. Are you saying gap them before the crossing?
Then on the north sided are turnuouts 2 & 3 #2 is gapped before and after the crossover #3 the diverging route is gapped after the crossing which is in contact with the straight route.
Again, I don’t understand crossings. Does that upper crossing, as drawn, get power for the diverging route off #2 from the connection to the straight #3 If the gaps are moved to the turnouts, isn’t there a short at the inner mainline, between 3 & 6?
Ok I thought about it and I am still confused. I had the correct wye, but that’s as far as I could take it.
I don’t understand the purpose of the red gaps, nor the gap closest to 2R. The remaining 4 yellow gaps should do what you propose, if the reverser is connected to the reversing section and the OP said it was. Unless there the electrical connection in the mainline is so poor and those extra gaps are causing loss of power. But that still wouldn’t change N & S with flip flopping the reverser wires.
Henry, let me try to answer your questions this way. The OP says that he is using Atlas turnouts, so dead frogs, not power routing. I am making an educated guess that he is also using Atlas crossings, so the crossings are not part of the problem since they are, so to speak, DCC friendly.
It seems to me that if he simply keeps those four pairs of gaps at the divergent ends of the four turnouts coming off the mainline, the reversing section should work.
Like you, I see no reason for the rest of the gaps marked red and yellow. That is likely the problem because he may have feeders outside of the actual reversing section.
I have a bunch of PSX-ARs on my layout, but I do not have any OG-ARs. When I look at a diagram of the OG-AR circuit board, the inputs and outputs are marked as 1 and 2. So, unlike the PSX-AR where the two output wires may be flipped without causing a short, that apparently is not so with the OG-AR. So, flipping the output wires with too many gaps and misplaced feeders may well highlight the problem.
So, my conclusion is that the divergent end of each of those four mainline turnouts leading to the stub end yard needs to be gapped to isolate the entire stub end yard from the double track mainline. No other gaps are necessary. Everything to the left of those four pairs of gaps becomes the reversing section. Those other gaps on the manline (red and yellow) should not be there. The two wires coming from the output side of the OG-AR should connect to any and all feeders inside the reversing section. No feeders from the output side of the OG-AR should be connected outside of the reversing section.
I would simply eliminate the insulators on the south leg, and install insulators on the north leg where the diagram has arrows and the numbers 15 and 16. The phase from the south leg would flow into the yard and the isolated north leg would be controlled by the reverser. There could be a question about the length of the isolated north leg however.
If those feeders are coming from the OG-AR, that would explain it. Otherwise everyone has feeders outside their reversing section.
I’m a little more skeptical that the output of the OG can only be connected only way. It’s a reversing section, rail 1 & 2 change constantly.
One more question, a crossing X is joined by connectors to adjacent track but only the track running from the top right to the bottom left is connected to the bus.
X
Does the track running from bottom right to top left have power?
Atlas crossings are jumpered so that power flows across the rails. Each of the four rails in an Atlas crossing is composed of three rail segments. If you apply power to any of the three segments, the entire rail will be powered. Each rail must be separately powered though, so at least four feeders will be required. I always power all four ends of every crossing, so a total of 8 feeders. Overkill, but why not.
Yeah, I’m not sure that it makes any difference how the output side of the OG-AR is wired. I only mentioned it because of the 1 & 2 designations on the circuit board. On my PSX-ARs, there is no such designation. That said, it is curious that different results occur when the OP flips the two output wires on his OG-AR.
Everyone’s replies are assuming the AR module is actually functioning correctly. It sounds to me like it’s not … especially the comment about switching the wires and the other leg works correctly. I’d be looking at the AR module and verifying it’s actually doing what it’s supposed to be doing first. The original description of the problem tells me it isn’t.
