I am reconsidering a roundhouse, currently I have a rectangular 2 bay building. Looking for ideas beyond Walthers and Atlas. I don’t really need a massive roundhouse, but all pics are welcome. There are old threads on this subject, but most have been photobucketed.
My roundhouse is HO and made from two Korber #104 kits. Most of my steam locomotives are biggies so I needed a deep roundhouse. I bought two kits so that I could extend the depth to 20”. Because of the large footprint I only have 5 stalls.
I goes great with my 135’ turntable (18½”) also to handle the biggies.
Thank-you. Yes, I think it is. It was a Cornerstone kit…is that right? It didn’t fit well with the Walthers 90’ “Built Up” indexable turntable. I had to set the TT back at least six inches from the pit flange lip and curve the bay tracks from the pit lip a bit.
Mine is made from the Cibolo Crossing Duango wall castings. Monster Models has this out as a kit now IIRC with their own castings. This older distant shot shows the location and approaches.
The framing.
The fron. The vent stacks are Grandt and the ventilators are Cibolo Crossing.
I used the Grandt roundhouse doors because they are based on those at Durango[;)]
At one time, I wanted to fit a small roundhouse on my layout, but I decided on making the space a transloading area.
Anyway, I did some googling around, and Voller, Heljan and Kibri also make kits. They might be a little to “Europeanish” for what your doing, but the Kibri roundhouse is a gable end, like a big barn, and not like your typical Atlas or Walthers kit. It still might be a little “Europey”.
Don’t forget scratchbuilding as an alternative! I recently completed the shell of a new 3-stall roundhouse for my layout (still needs a few details). The base building is made of .040" sheet styrene. The siding is printed on paper using Evans Design software, applied to the styrene using double sided tape and weathered with artist’s pastels. The roofing is 220 grit sandpaper applied to the styrene roof using spray adhesive, then weathered with pastels and an alcohol thinned black wash. Window castings are from Tichy Train Group. The greatest advantages to scratchbuilding are that you can make a building that can’t be found on anyone else’s layout plus you can create a building that fits your layout style, era and space. You don’t have to lay your tracks to fit someone else’s building!
I don’t have much to show as my RH is currently topless. I just thought I would mention that I placed my TT and RH on a removable piece of foam that I lift out and take into my office to work on. The electrics just unplug. Come moving day I will be able to move the unit as a whole and place it in the new layout.
Crandell, what colour is that on your RH doors? I like it.[tup]
