Sick BLI Paragon 2 AC6000
I have 2 of these, and had them set up for the easy consist 60. Suddenly, it seemed the 2 were running slugish. I noticed the rear loco was not even running. So I created a Digi consist on the controller and thought I would use that to do the consist… neither loco would work then. So I went back to consist 60 and the front loco worked still. So I deleted that consist so that the front loco was indipendant (unit 7500). I did the same for the back loco, unit 7501… but still 7501 does not do anything. I tried to set cv8 to 8 and nothing. So I think I need to do a hard reset but I dont know where that button is.
I noticed the top of the rear comes off, just above the blowers and I see the circuit card, but no button. What is my next step?
Try this link
http://www.broadway-limited.com/support/Paragon2%20Reset.pdf
I had forgotten about the service mode programming. I did the CV8=8 with that, and it works now.
As to that link…how do you get access to the decoder? The lid that I remobed does not let you get to that button… are there instructions on how to pul the shell off? (assuming that is what you need to do?
