I’m bewildered by some signals I see on the UP. So on a signal head you usually see three lights as follows:
o - green
o - yellow
o - red
But on the UP I see signal heads with four lights and I have no clue what the other aspect is. I’m assuming lunar but never seen it lit. It would be in the pattern of:
Well nobody has commented and I know nothing about the UP so I can only speculate since the PRR had a similar situation. The PRR had a light mounted lower on the signal mast that could be lit to allow a train climbing a grade to pass a red signal IF it would stall on the grade otherwise. There were serious speed restrictions associated with the maneuver and the engineer had to be able to avoid a collision knowing there was another train in the block ahead. It could be to allow something similar.
I know just what you are talking about and I am unsure also. I do have an idea though, it may be white (also called lunar to some railfans). On former B&O signals it indicated speed restrictions. On modern CSX signals I’ve seen them being used to indicate a train meet.
If I am wrong on this I would like to be corrected, but I am pretty sure!
it isnt just used by railfans…that color is called lunar white… when used in a traffic like style signal head it shows the indication of restricting… aka prossed at restricted prossed…
Not aspect, but light. The aspect is the totality of what’s lit, such as red-over-green, flashing yellow, etc. The fourth head is usually another yellow light, so the signal can provide a yellow-over-yellow aspect, which is a diverging route indication.
There are hundreds if not thousands of lunar lights on UP. The most frequent use is the entering signal for a non-bonded siding, where the best possible aspect is red-over-lunar, indicating diverging route, restricted speed. Many of the sidings on the former Western Pacific and Oregon Short Line are non-bonded.
