I can’t believe I have to ask this, but I do. When using a 110 trestle set, how do you incorporate a bridge, such as a 214,314, 316 etc.? Obviously it will go between the “A” piers, but how is it secured? Thanks for any help!
So far this is all I’ve found to answer your question. My bridges are stored away for the time being so I can’t experiment. I should think you have to screw through the track, bridge and into the trestle.
Personally I wouldn’t use a #110 trestle, it looks too flimsy, but build something of my own.
Thanks for the info. I think you are correct. I was playing around with them last night. I decided not to use them. I think I will do as you suggest and build my own. They did seem more flimsy than I liked for a permanent layout. Thank again!
Mike
