Single Crossovers built of Peco larges
I was rummaging thru my stowage trailer today and found a whole new bunch of Peco large radius turnouts. So now I have more than I need. I went back and started looking at areas where I might insert the large radius Pecos for the mediums,…found a few.
Got to thinking about substituting two large radius Pecos for the single crossover Shinoharas? Looks pretty good visually, and would save me from replacing any metal throw bars on those older Shinoharas. Has anyone had personal experience with such a crossover using the large radius Pecos?? DSCF4427.JPGDSCF4428.JPGDSCF4429.JPG
I realize the diverging tracks on these Pecos and the Shinoharas are different, but in this larger radius configuration it does not look to be a problem?
The Pecos have a curve through them, so making a crossover makes a bad S curve, even worse than two turnouts with straight diverging legs.
I do understand that they make an S turn, but in these large sizes it does not appear to be bad at all??
Theoretically true, but the diverging curves are pretty gentle. Hundreds (likely thousands) of layouts have used the PECO HO Code 75/100 Larges as crossovers successfully.
thanks Cuyama
I also saw this, that would appear to reinforce the idea of using the large size Pecos,…
I also like the idea that the spring loaded Pecos maintain a better rail to rail contact than do the Shinoharas which I understand have some consistancy problems here.
I have also decided to utilize the Peco PL-10 Turnout Motors (Solenoids) which will fit nicely in the round hole drilled into the 3/4" plywood deck topped with 1/4" cork.
Well, lots of things work well in practice even when the theory sometimes says they won’t [:D]
Large Radius are pretty large, so probably fine for most stuff that should be running on a layout that size. Just don’t try to fudge anything by adding say a short piece of flex between the two.
I mean - regular #6’s in a crossover aren’t supposed to work for larger steam locos and long cars, but I had no problems with up to a 4-8-4, and full length 85’ Walthers cars with diaphragms. I think that was the biggest loco we had back then - might have had one of the PRR I1’s as well, although I don’t remember if the BLI model has all drivers flanged. Wasn’t my loco.
The solution here is obvious. You already have the large radius Pecos. Set up a pair on the workbench and try it out for yourself. Then, come back and relate your experience to us.
For what its worth, I have crossovers on my layout made of Peco medium radius turnouts. My 4-8-4, 4-8-2, and 2-8-2’s all roll right through. 85’ Walthers passengers cars do as well. All at speed too. Should be no issue with the large radius ones.
Thanks for those reassurances. Couple of reasons I would like to use the Pecos rather than Shinoharas
  1. Don’t have to fool around with those solid connected throw bars between the rails.
  2. I like the Peco spring action.
  3. I have decided I can power-up more turnouts than I originally intended,…and with the Peco turnout solenoid. Since I am going to include 1/4" cork roadbed under most of my track, and its sitting on 3/4" plywood, that gives me a nice 1" deep hole to set the Peco solenoid in without any projection under the deck.
I utilized CD discharge to power atlas turnouts on my first layout and those worked just fine. And the Pecos appear to have a more robust solenoid than the Atlas ones.
