Have you looked at model shipbuilding supplies? I did a quick check and found some wood pulleys that might work for you. They might have brass ones, but I didn’t see any.
I was doing some searching myself and most of them are in the UK…I wonder why that is? US can’t make brass pulleys? Anyway,I ran across this place and although they are based in the UK.they have distributors,here, TECHNOBOTS www.technobotsonline.com pulleys&cams,5,6,7,8mm pulleys…Maybe,they can help…In the mean time I’ll keep looking,LET US KNOW,IF YOU FIND ANYTHING…
Or maybe some of the pulleys that come with logging equipment, and crane parts. I’ve also made some parts by chucking a piece of sprue into a drill, like a lathe, and using files to shape what I was looking for.
I have a little more time to look but I might have to go to plan B.
As you may remember from my original drawings I made the lift wheels with 2 HO train wheels glued with the flange on the outside. This caused a slight v in the center. Since we scale the lift down I might go with the same concept except with N SCALE wheels.
I agree,with you,rather than sitting on our hands,go with the N-Scale,wheels,After all don’t we have the,‘‘Best Mechanical Engineer’s’’ working on this project?? Heh,Heh…
Frank, your right about anything plastic. Just tossing out some ideas, as I’m always digging through my various parts and “junk” boxes, looking for something, that will work for whatever project I’m on. Another idea, I have a couple of the wrecking cranes, both of which are fully operational, and they have metal pulleys.
I find it hard to believe, too, but I believe I suggested, in your original thread, to check out the ship-builders supplies either at your LHS or on-line.
If you want pulleys suitable for the job, why not simply make your own? Determine the approximate outside diameter needed, then buy a length of brass tubing of that diameter. Buy a second length of tubing in the next smallest diameter, and a length of piano wire similar to that of the inside diameter of the smaller tubing.
Clean the inside surface of the larger tube using fine wet/dry sandpaper (use it “dry”), and do likewise to the outer surface of the smaller tube. It’s unlikely that you’ll be able to clean the inner surface too far into the tubing, so you’ll probably be able to make only two or three pulleys at a time. Apply a little flux to the outer surface of the smaller tube and insert it to the necessary depth into the larger tubing, then heat and apply solder. You can use either a good-size soldering iron or a propane torch, similar to that used by plumbers.
Cut off the protruding portion of the smaller tube, then shorten the larger tubing so that only the double-walled portion remains. Insert a similar length of piano wire into the tubing (this will prevent the tubing from being crushed by the chuck) and chuck one end into a drill. Clamp the drill into a bench vise, then, with it running at medium speed, use a cut-off disc in your Dremel tool to cut a groove for the cable. Don’t allow the cut-off disc to go any deeper than the thickness of the outer tubing, and when the groove is satisfactory, use the cut-off disc to cut the pulley from the stock material. Your initial efforts may be less than satisfactory, but should improve with a little practice. Work slowly and be sure to wear eye protection, both to safegua
