Hello,
I am wanting to put on the walls about 2 feet above the ceiling.
A ski lift / trolley system. that can go around pulleys in a continous motion.
The only thing I have been able to find, that is close is the LGB Lehmann rigi duo.
But it’s not a level system and does not go around the pulley only up and down.
I was even thinking of mounting pulleys on each corner of the walls and have it go all the way around the room.
http://www.shopatron.com/product/product_id=LGB89591/394.0.16742.0.0.0.0
this is a link to a ski lift system, but as I mentioned it does not go strait across or around the pulley. It has auto switch that makes it go up and down.
So, I was hoping someone has does something like I am wanting to do. unless someone might know who makes or sells what I am wanting.
which is a wire trolley, not a train trolley. or a ski lift / gondola that can hand and run on a wire / rope / string. Going around the pulley. with having a motor turn one of the pullies for the motion.
Also where I might find parts to make or adapt a system that will work. I want to do this for my childrens room.
Thanks,
Sporty
