I currently have a home built routed on MDF 1/32 scale slot car track. I want to incorporate a railroad as part of the layout. These railroad scales are confusing. Can someone tell me what scale / guage is equal to 1/32 and where is the best place to get equipment (track,engines,cars,etc) and scenery.
None that I know of. O scale I believe is 1/48. I’m not sure about G scale but I think it is about twice as big. That puts your 1/32 in between those two. I’m not aware of any scale in between but I have discovered some odd scales that I was previously unaware of that are in use in foreign countries.
1:12 Large Scale
1:13.7 7/8 inch scale
1:20.3 G, Three-Foot Gauge on Gauge 1 Track
1:22.5 LGB and Bachman
1:24 Half scale
1:29 Aristo-Craft, USA Trains, standard gauge on #1 gauge
1:32 I scale
1:48 O scale
1:64 S scale
1:87.1 HO scale
1:120 TT scale
1:160 N scale
1:220 Z scale
It looks like “I” scale is for you. Perhaps someone here can direct you to some help in this scale.
Years ago, either Bachmann or Aurora made a piece of track for slot cars AND model railroads. Unfortunately, it was for HO cars and trains, which does you no good. You could sell the 1/32 slot car set and switch to HO. Only, if you go that route, I would make sure that you can find that piece of track somewhere.
1/32 is sort of a fine scale version of G scale. Few manufactures use this scale and the ones that do are usually high priced brass/limited run type stuff. Not worth it if slot cars are what you’re really into. Although MTH (Railking line) offers more affordable 1/32 scale trains (see the first link I posted).
If you can handle the slight difference in scale use 1/29 standard gauge on 45mm track Aristocraft offer diesel and steam locos and a range of track. USA trains also have a good range of modern and a few older protoypes.
Even if you can’t find that piece of track, the switch to HO will be a good one. You can always run inside or outside of the rr track. Double ovals of car track with the back side hidden by scenery will give you a two lane road running beside your railroad. If you can find the piece of track mentioned above (I think it is a road crossing the railroad), you could have some of the neatest crashes known to the mr world![}:)][:D][:p][B)][:0]
When Aurora marketed that grade crossing section, their advertising featured a train punting a car into the boondocks. That prompted several legislators in a number of jurisdictions to try to outlaw the model, on the grounds that it would lead to full-size idiotic behavior when the slot-car drivers graduated to street rods.
Imagine the uproar in today’s, “Outlaw everything even marginally unsafe,” political climate!
Thanks for all the help. Ill post pictures when I get it done.
That is really funny about the HO train / car crash. I remember that track from when I was into HO a long time ago.
All those kids who saw that ad are driving in Seattle today. Those legislators must be Ted Kennedys age by now. You may already know this but 1/32 scale is 3/8" to the foot. Still ough to find model railroad equipment in this scale.
I scale or 1/32 scale uses “G” gauge track to model standard gauge railroads. It is a specialty scale, and very expensive. I don’t think that anyone makes a grade crossing for 1/32 scale slot cars and G gauge track, though–could be an interesting project-within-a-project.
Consulting the large-scale/garden railroad forums might produce more useful answers.
Actually, I have that Aurora train crossing and the track that goes with it. I’ve always meant to include it in a layout but haven’t to date. The car track does take up quite a bit of room. I was thinking it would be possible to use the HO scale cars if they passed through one or maybe two small areas of a layout.
