Threw the instructions away. HELP! who ever has the code 83 Atlas snap switches, where does the red, green and black wire go on the supplied controller when the blue button is on top. I came to this forum because I am wiring right now and saw people in it.
Not having the exact item in front of me…wire color means nothing to me. The snap controller and turnout motor are wired the same. Center on both units is common and the ends are the ends. If you prefer to turnout points to set one way when the blue button is to one side and it needs to be reversed, simply swap the outside wires. The center remains the same.
