We had our “Club” meeting at the house on Thursday and looking at some of the posts I thought this may help some people.
The train crew was trying to move a 4 car Rivarossi passenger train from Ashley to Nanticoke. A little Background These are not STOCK Rivarossi cars. They are all modified according to Andy S’s article in Passenger Train operations (sorry about the title, may be off). THey are Body mounted couplers running on 30" Min radius mains.
So as you can see they should be fine. THey had the cars uncouple (tiny dip in track) so they fixed the track, ran over that section about 6 times and moved on. Get to another section and the fun started. Baggage car derailed. Pulled the Baggage car sent it to RIP. Guage was checked, coupler height, coupler movement in box and luberication of the wheel sets. Returned from RIP and tested again. Derailed at the same location. Back to RIP!
At this point the trucks where rechecked and someone decided to check the trucks for swing. THe truck was found to bind on the coupler box which caused the truck to freeze in place and climb the rail. Some file work and the car was returned to the track. Ran forward and backwards to make sure that it was the car not the track work. This fixed the problem.
The one thing that you should get out of this is that these are SMALL TRAINS and they do not required a big problem to derail. We are pulling all the paseenger cars off and checking for this problem. (76 cars). We have been converting all “NEW” kits to metal wheels sets it they did not have them. THere are 65 or so OLD cars that are going to be weighted, Kadee’s added and then run throught the NMRA check. We will then run them in a test train. If all is well they will go in service with Plastic wheels. If they have a porblem we will change to Metal wheels ( Proto) if they STILL have a problem, and they do sometimes, new Kadee trucks will be installed.
We are having a better than 85% success with not having to cha
