Hi FJ and G,
I do not have the 22-811, but I went to radioshack.com and looked at the manual.
You said, “The instructions are TERRIBLE…”
That is common. Writing manuals is difficult to do well.
The on-line manual has an error in the section titled, “MEASURING DC/AC CURRENT.”
IS:
6. Apply power and read the current.
If the measurement is less than 400mA,
connect the red test lead to + 10A MAX,
and proceed to Step 7.
SHOULD BE:
proceed to Step 7.
You state, “I cannot offhand think of anything that would be over 10 amps.”
I just applied my Radio Shack RS-232C to the terminals of my Lionel 1015, 45 Watt, 8-15 VAC transformer. The reading was 13.01 Amp AC. (Measuring transformer terminals with meter set-up for AC Amps measures the transformer’s short circuit current - not a good idea. Don’t try this yourself. Heed wrmcclellan’s warning.)
My Lionel 5366 SD-9 measures .15-.22 Amp AC in neutral (just lights on) 1.20 Amps AC running light @ 8 VAC and 2.7 Amps AC stalled @ 15 VAC.
Ten amps should work fine for measuring current in individual items.
The on-line manual does not give limitations on how long you can measure ten amps. If the area around the current terminals gets hot, use good sense and limit how long you measure maximum amps. Warm is normal.
SPFan said, “Very few multimeters I am aware of can measure AC current.” The on-line manual states that yours can.
Regarding fusing, the on-line manual states, “+ V.Ohm.mA is fuse-protected.” Note that the ten amp range is not included in this statement. No fuse is good and bad news. Good if you measure the short circuit current capability of a 45 watt transformer, because there is no fuse to replace afterwards. Bad if you are not fast at reading the 30% over current and smoke the 10 amp curren
