Did you mean Item # 81774 - “101 Assorted Springs”??
I got that but most are between 1" & 3" long & way wider than I need - outside the ‘super small’ range - did I pick the wrong item??
Thanks
Tanked
I didn’t go through the metric to english dimension exercise, but I will say that my local TruValue hardware store had a selection of very small springs. They were in the area where they have a lot of drawers with all the different size nuts, bolts, washers, cotter pins, et cetra. It was a small box that had a selection of various types of very small springs. The large screen door springs were hanging somewhere else.
Check Northwest Short Line. They have an assortment of springs that may suit your needs. For example, they offer springs to fit steam locomotive driver suspensions.
Had I searched in Imperial rather than Metric initially I may have cirumvented the need for these posts. However, I have mentioned the above source in case other people are looking for small springs.
Those NWSL driver springs are just very small coil springs. roughly 2mm in diameter x 2.5 - 3mm tall. All the springs I have are currently installed in my loco’s so the height measurement is an estimate. The “light” and “whimpy” designate the spring rate.
NWSL was originally in Seattle, but was purchased last year by a Montana --based new owner. They are now in Montana (see www.nwsl.com) and there they will be for the foreseeable future.
You don’t have to buy one. Just go to the Walthers site, www.walthers.com, and put “spring” in the search box. Unfortunately, you won’t in most cases see what the springs look like, but I’m not sure that the paper catalog will have any better descriptive information than what you’ll get on-line.
I had a look. Searched ‘springs’ & got about 13 pages - anything with ‘spring’ anywhere in the title or description.
The problem with the Rivarossi springs I have been looking for is that for their functionality they are pretty specific as to diameter & wire thickness. They go over a bolt & fit inside a ‘tube’, so diameter is critical.
Whilst in the Walther’s catalog I looked up Rivarossi & noted not a lot of items & many of those were showing as ‘Discontinue once sold out’
Are Walthers still the main Rivarossi distributor in USA or has that been sold off to someone else?? - for a main distributor I thought stocking levels were low.
