Hi Everyone - I am relatively new to the DCC sound world - i have been using DCC for about 2 years but had no DCC sound equipped engines (ok I’ll wait until everyone finishes gasping for air). We I picked up an Atlas Trainmaster on ebay for a really good price and now of course i want sound in everything. I am on a tight budget so I have waited to buy on sale. Well I found a really good sale on an MRC 1639 decoder and a 28mm speaker (really? mms? where are we? France?). I know they are not popular and I know the reasons (thus why i probably got it so cheap) but figured I’d get my feet wet with a cheap decoder first. Then I’ll dive into a Tsunami decoder once I have a handle on arranging these things. My question is this: The sound decoder came with a speaker that has a little black baffle on it - why is the speaker pointing into the baffle? Shouldn’t the speaker be pointing out and the baffle be on the back of the speaker? I plan to install this in an IHC 2-10-2 which has holes already made in the tender floor and a place to insert a speaker. Do i take the baffle off and point the speaker downward towards the track? Do I leave it on and place it in the area where the speaker goes (essentially pointing the speaker up to the coal load)? This is an 8 ohm speaker and measures to be about 1.1 inches so its a decent size.
That is like buying a cheap, rancid wine to see if you would enjoy wine. Bad idea. Always buy the good stuff to get started. The quickest way to put yourself off of sound is to have a bad experience with a terrible decoder. The better way is to save your pennies and purchase something of better quality and enjoy it.
ANYWAYS, the speaker produces sound wave equally through the front and back of the cone. Therefore, the speaker can face into the baffle just as easily as it facing out. However, with the speaker facing in, you are protecting the cone from metallic debris.
Thanks David - I know the choppy waters I am wading into (I have read plenty of your posts!) - I am on a bare bone budget and the $40 i spent on the decoder and speaker seemed too good to pass up. I really just wanted to find out about the speaker though and you have been very helpful with that and I thank you.
Does the speaker cover all the holes in the tender floor? If not then you will get a lot of sound cancellation and distortion. If the speaker is larger then you can toss the enclosure for it and use the tenders shell as an enclosure. General rule is the larger the enclosure the better the sound. Always fit the largest speaker you can. The ones that come with the decoders are sometimes good enough but if the tender is big enough then I either use 2 speakers or one larger oval shaped speaker.
Loksound Select decoders are just a few $ more then that Chinese made thing you got.
Pete - thanks for the tip - I have never even heard of Loksound so I will now do some investigating into them. This is going into a VERY large tender. From what I can tell IHC used the same 6 wheel trucked tenders that Rivarossi used on their Pacific engines. The thing is huge! One other question now - you said use two speakers - is there no danger in using two? Can you harm a decoder buy having it power too many speakers? (this is generally speaking - not necessarily relating to my choice of decoder)
The direction the speaker is pointing is irrelevant. When the cone moves it moves air. The moving air makes the sound. I don’t know why that specific speaker is pointed that way, might just be that it was easier to mount it that way, OR the speaker magnet does not fit into the baffle.
The IHC is set up for the tender body to be the speaker enclosure. I would get a speaker that exactly fits the pre-defined place in the tender. As the others have already said any air excaping around the edge of the speaker will lower the sound volume and probably quality. Likewies I would not put the pre-baffled speaker into the tender facing up. That would block the holes in the bottom and there would be almost no way for the sound to excape.
I have 8 or 9 MRC decoders, 1634s, 1800s, etc, along with Tsunamis, and Soundtraxx. Heres my take on the MRCs. I have never fried one or had it just die. All are still working in various locos. They are too loud, and you can’t turn down the volume. Motor control isn’t the best. You can program the address, and not much more. Most don’t read back CVs. A couple do. Occasionally, they lose their address, and have to be reprogrammed. But they are cheap, and include the speaker. And they are a cheap way to get into sound. I have no plans to buy any more MRC decoders, but they aren’t the total junk that some are claiming. And they cost about a third of what the Tsunami costs.
The reason the speakers are mounted firing into the baffle is because the contacts are on the back. If the speaker is mounted the other way, as I have done a few times to get enough clearance, then you have to drill a couple holes in the baffle or one hole to get the wires onto the back of the speaker. Then you have to seal the hole with something. It’s not a problem, but they are saving a step of labor mounting the speakers that way.
The biggest advantage of having the face of the speaker in the enclosure is that it creates a larger volume IN the enclosure. The other way around, the speaker magnet is taking up valuable airspace within the enclosure. The more air volume within a sealed enclosure, the better the sound reproduction. Of course in a lot of cases, we just don’t have the room to do this.
Actually, pretty typical of MRC. They give their product an initial high MSRP value and then slash the price in a month or two to give the illusion of a bargain.
While the speaker produces sound on both sides and pretty equally. The nature of the shape of the cone itself and unobstructed cone makes forward facing a little better. Also metal cones and bigger magnets can make the difference even moreso. And the speakers with metal cones and bigger magnets normally sound better, particularly at the lower frequencies.
You can play with bouncing the sound off of the layout, that is downward facing speakers or up, or even as Atlas does in their diesels you can form a teepee where they face each other and then down. This installation allows for larger round speakers. I normally put 2 speakers in each loco, with at least one being a high bass type or bass reflex. A good speaker is around $8 or so. Some places I normally go to are:
Pay attention to the frequency range, materials of construction, size, ohms and watts. And since you’re experimenting, I would suggest you try a large speaker and cutting it down some. You can gain .100" to .200" this way. Also, make your own enclosures, the bigger the better and experiment with materials of construction for this too. Don’t be afraid to use the loco shell as part of your enclosure.
Thanks for the link. And he liked the forward facing speaker better, so did I. But it’s of course preference and install considerations. BTW, I use thick cardstock for enclosures many times and have good results–similar to the effect of wood and helps with isolation and clarity of sound.
With multiple speakers you’ll need to wire them to match impedence with the output amplifier of the decoder.
Determine output rating and then configure speakers appropriately. For an amplifier with 4 ohm impedence (typical) use 2 8-ohm speakers in parallel. Or 2 2-ohm speakers in series.( And make sure they’re in phase or the sound will be truly awful).
Impedence mis-matching is the “danger” you’re referring to. If your total speaker impedence falls below rating for the output amplifier (i.e. decoder), you’re likely to destroy it.
