Tom i found on Pinterest wher you had put stained glass windows in the second story of a building and I was not familiar with the term vue-graft. are those just picture negatives? Redoing an old torn up piko church and that would look cool in the windows, Thanks Bill
Bill;
Vue-Graph: 1960’s classroom technology. Big box with very loud fan and bright light shining up through a glass plate, focusing mirror, about 18 inches above glass plate. Teacher puts 8 1/2" x 11" clear acetate with a graphic on the glass plate and projected on a screen. The acetate has different sides. One side smooth and ‘sealed’ can be drawn on with ‘water pens’ (erasable marker) that can be wiped clean. Second side is microscopically rough and porous, image is permanent.
The acetate sheets are still available in the BIG office supply stores, especially during the holidays for hand made decorations ‘water glued’ to house windows. They can be found in the label section between the sheets of 1/2"x2 1/2" mailing labels and the single sheet 8 1/2x11 labels. Now days they have a removable 3/8" white strip so our printers and copiers can “see” the sheets. the strip is on the ‘rough’ side, where our ink jet and laser printers, print will stay in place. If you ink jet print on the smooth side, the image will wipe off if touched too soon. Allow the image to dry on the ‘rough’ side for 2~3 minutes.
I print the window art on one sheet, then glue (Elmer’s Spray Glue
I have also used this method to put curtains and window shades inside buildings. My daughter was excited when I put a pic of her as a toddler peaking out behind the curtain.
With very limited success I hung a large actetate ‘picture’ inside the building showing furniture. From the correct angle it gives an alomest 3-D effect.
More ‘Vue-Graph’ stained glass window and curtains. Base strucure was a bird house from Michaels.
Well I chickened out and bought windows off ebay, found dealer that would make them any size, pictures of real stained glass, they were sandwiched between to sheets of plastic and sealed, The ones I picked were exactly as pictures but when I got them they just didn’t show up well in such a small space 7/8" w x 7/8" h so I colored them with sone permanent markers. Good luch with your raised bed my back feels for you, Bill
Getting light behind the stained glass windows is important. The hotel you cited has 4 rather large skylights in the roof as well as 3 lightbulds for nightime lighting. They are by definition small and hard to see but enough light from behind will make them stand out.
