Hello,
I have a BLI Heavy Mikado (2-6-2) that I recently purchased that has been shorting (it turns itself back on) when crossing an Atlas 90 degree crossover at very slow speeds. Basically when the last 4 tender wheels land on plastic parts of the crossover the locomotive shorts out, then kinda sputters and turns on again and proceeds on.
I’ve checked with a multimeter that there definatly is power to all parts of the rail.
The first 4 tender wheels are on powered track as well as the last 4 of the driver wheels. I thought that maybe because the 1st four driver wheels were on another crossing that this combination was causing the short, so I purchased another 90 degree crossing and ran the locomotive very slowly through it and the same short happened.
I do have 2 other steam locomotives from Bachmann (both 2-6-0) that run perfectly fine thru the crossing.
I’m really puzzled why the BLI is having such an issue. I’ve attached a picture for more clarification.
https://farm1.staticflickr.com/806/40973083781_044a3c587c_m.jpg
