Hello All, any body out there have a wiring diagram for a Lionel 10E with a pendulum reverse unit? I have a unit with some wires missing and the rest crumbling. Thank you for your response(s) in advance.
Hello and thank you for your reply. The diagram you sent me was from the 10 which uses a manual switch (round object with the wires in your diagram). I have a 10E which has a pendulum electronic reversing unit. I did however manage to scrap up enough pictures (from E-Bay and other sources) of the motor plus pull another 10E out of my box that had enough wire left on it to piece together a good diagram and get her running properly again. I will refine the diagram in Visio and post it here when I am finished in case anybody else has a similar problem. Again your reply was much appreciated.
