Dear Sirs,
I did NOT think of draining Down the Warm Water to Warm Side Sheets behind the Bricks, but good Idea!!!
As we have a BIG Stationary Boiler, I DID suggest Lifting Water from Tender using House Steam on Locomotive Injector as it would warm Water on Stone Cold Boiler after Wash Out.
Previously we tried moving Hot Water from Stationary Boiler to Locomotive thru 1 Inch Pipe. Pathetic!!
Then Filled Locomotive Boiler with Cold Water with Fire Hose and Applied Live Steam to Blow Down to warm Water , also very Pathetic, and SLOW.
One year we Fired Locomotive on Wood to Raise Steam before Firing On Oil., Draft from Big Air Compressor. Doubt Wood Fire did Bricks any good, tho’, but worked.
Tried Firing on Oil using Compressed Air instead of Steam on Blower and Atomizer/Burner. Works! Flame is Different, and the worry of Condensate coming thru Burner from Steam and putting Fire Out when everything cool is lessened. We were Burning Diesel and Oil Temp not a problem.
Disconnected, then Removed Tender Bunker Oil Heater when New Tank Applied. Disconnected Steam Supply to Oil Line Heater on Oil Supply Pipe Beneath Cab to prevent accidental Heating of Diesel.
Diesel is Fine, but has to be watched carefully, as very Volatile. If it goes Out and you are NOT RIGHT ON IT, a Fire Box Explosion WILL result if Reignites on own!!! Scary, Scary, Scary!!! Watching Unlit Diesel creeping towards Red Bricks is Heart Stopping viewing thru Sand Hole in Firebox Door. Stand in Gangway, if Time.
We had a VIOLENT Firebox Explosion that Burned Off all Exposed Hair of Engine Crew and Blew Out Asbestos Rope Packing for Draft between Firebox Brick Pan and Mud Ring. Blew Out Packing between Smoke Box Front and Smoke Box Proper .
On the Road if Fire Goes Out. Shut Th
