Straight facts on couplers
Look here: http://www.micro-trains.com/conversions/sheet007.pdf
More conversions here: http://www.micro-trains.com/conversions_n_pdf.php
Rotor
Thanks man. It looks like I need a 2001(001 02 050), whatever the other numbers mean…
How much juice do you have to run to get it to jump through a plastic draft gear box to the shank of a metal coupler? Why a nylon screw? The plastic draft gear box should electrical insulate the coupler from whatever it is mounted to. If not, You didn’t do it right.
2 Couplers need to MATCH each other. “Compatibility” is just another word for ‘almost’.
dstarr: is right on re HO Kadee’s. (N scale, I don’t know). ‘SHELF’ couplers belong on tank cars, period. Prodigious use may aid in ‘String lining’.
WP 3020: A metal coupler in a plastic box, using a metal screw, will not be insulated from a metal chassis. That’s why the series 30 couplers.
(plastic screws tend to bind and break in the hole).
Maybe I’m confused, but the Kadee Platic boxes that I have, have got a little plastic bushing in them. I’m pretty sure they will electrically isolate the coupler, no matter what screw is used.
But…I’ve been wrong before. [:-^]
Rotor
Don Gibson:
Maybe you forgot “plastic box”? where does the “metal screw” come in direct electrical contact with the “metal coupler” when using a plastic box? If you do not use a plastic box for mounting your metal coupler to a metal chassis (like an Athearn or Bowser etc.) you will have problems with electrical continuity (and probably more) issues to deal with. Please, if you have a continuity tester or ohm meter could you check for an electrical pathway from a metal 2 56 machine screw through a plastic Kadee draft gear box to a metal coupler? If you modify the metal mounting pad to accept a plastic draft gear box (as I said before) you can use a standard metal non insulated shank coupler. The properly assembled and mounted plastic draft gear box will insulate the metal coupler from a metal frame.
Rotorranch: / WP 3020:
You are correct - as long as the metal screw doesn’t touch the the metal coupler & spring; and then there is the newer ‘Whisker’ coupler that depends on the (supplied) OEM housing.
Perhaps the key word is ‘proper installation’.
Huh Don,the plastic coupler box will insulate the screw from the brass spring because the KD coupler box has a plastic screw housing.
I’m lazy…[:-^]
Since I don’t have that many Athearn Locos, I just use the insulated (plastic shank) Kadee couplers. [:D] I’ve only broken one or two in the last 15 years or so.
Rotor
Perhaps.
Herr Wankel:
The plastic Kadee’s may be tougher than the other plastic’s. Since changing to ‘super roller’s, I’ve broken that number of metal ones - rolling and hitting stationary cars (Whack!)’ I’ve taken out the incline. Also, 30 series comes in assorted shanks, + there IS a # 38 (insider joke).
BRAKIE: I think you are referring to Kadee’s molded ‘bushing’ the shank pivots around. The flat spring has a hole. (Dare we call it a “whole, hole”?)
WP: ARE you one of Joe Fugate’s Siskiyou boys?
With you on that
I live roughly 100 mi. South from him, we both know some of the same people and may have attended the same events but we haven’t met face to face, that I know of, yet.
True. One of the former members of the Nscale club I’m with remarked that technically Rapido and MT couplers are compatible after seeing two trains bump and not being able to separate them because a Rapido slid under an MT and hooked around the MT’s trip pin.
Yeah, in some circumstances this actually does work. Doesn’t look too good though.
Its simple just follow the chart that Kadee has. Theres a reason for the differant couplers, height of car or loco, draft gear, radius of curve, a number differant reasons. Follow the chart for your application.[2c]
