So after reading all over the net i am wondering, what is your preferred DCC BUS wire, stranded or solid? I have decided to go with 14 AWG but i am not sure which to go with, stranded or solid? Any tips or help is appreciated…Thanks!
It does not really matter if the wire is solid or stranded. It makes no difference electrically.
For your DCC Bus, stranded is the better choice, as it can withstand flexing during installation, routes easily, and is less likely to be damaged when stripping the insulation.
The gauge of the wire is also important. You did not mention which scale you are working in. Short bus runs in H0 can use 14AWG, for longer runs 12AWG is recommended.
suitcase connectors work better with solid wire. They are for two different gauges. 18g bus and 22g feeders are appropriate.
Each option has it’s own advantages and disadvantages, but I generally prefer stranded wire, because if you bend a solid wire to much it has the possibility of snaping, and when there is only one solid wire, that means you’ve need to replace the wire. With stranded their a number of redundant wires which will hold up better. The disadvantage is stranded it a bit hard to solder but if you twist the wire and them tin it, it will be a lot easier to solder (you should probably tin irregardless).
Does not matter, but I always use stranded because when you get to the larger sizes like #14 and #12, it’s a whole lot easier to pull around under the layout if it’s stranded. I use solid for the feeders, so there is no chance of a stray strand at the rail.
I don’t use suitcase connectors, so that’s a non-issue. What isn’t soldered goes to terminal blocks and I put ring terminals on the ends of the wire for that. The trick to soldering bigger wire sizes like that is to use the approriate tool. The low wattage iron you use to install decoders or solder feeders to the rail will never heat it up enough, or it will, EVENTUALLY, after spreading the heat a foot to either side of where you are trying to solder. Soldering feeders to a heavy gauge bus is where you want that 150 watt or larger soldering gun.
I used 10 gauge solid for my layout , eight different runs with spade connectors onto the [lit] switches …
For the feeders I used stranded wire from printer cables to go up, every three feet or so … It was just what was handy at the time, none of it was bought for purpose,
Whatever works for you, within reason I suppose …
Thanks to all of you guys for your input. I ended up going with 14 AWG for my N scale layout and i plan to use suite case connectors and terminal blocks…Thanks again!
i think suitcase connectors for 14g solid wire match 18g. would you use 18g for feeders?
I recall reading somewhere that DCC simplified wiring, as compared to DC.
Here’s what powers my layout, with approximately 260’ of mainline which doesn’t include staging, double track or industrial sidings (all track is soldered together)…
Admittedly, as the sole operator, I don’t run more than one train at a time (no “blocks” to allow it), but I have run more than a dozen locos at one time, and usually run two or three locomotives on most trains, due to the many curves and relatively severe grades.
Because the layout is point-to-point (multiple points), it’s not suited to multiple operators, nor is having additional operators desireable.
However, to answer the original question, if I were to convert to DCC, I’d still solder the track together, and use only two feeders, but perhaps with somewhat heavier wire.
However, not being all that conversant in DCC (I recently built a Bowser steamer for a friend, though, and successfully installed DCC in it), I’m wondering why I haven’t read of anyone doing it in this manner, as it would save a lot of work (and wire).
If my DC equipment can push 12 volts through all that track with no voltage drops (none of those locos slowed appreciably as another was added), then I’d think that a decent DCC system could accomplish the same with its 15 volt output.
Obviously the rail is a decent conductor and larger than the wire gauges mentioned, so I’d think that the additional digital info in the DCC output would not be impeded, either.
Has anyone tried running their DCC layout with soldered rail joints and no bus wire?
Wayne, are you saying that you run 260’ of mainline track, all soldered, off a 12 volt DC power pack with one pair of feeders and no voltage drop?
I only run one reeder to each block, sometimes 60-70 feet of track, I have never had voltage drop issues in DC.
Like Wayne I solder all my rail joints within each block.
Wayne’s example is only 3-4 times my longest blocks…
I do run a #12 wire throttle buss around the room from the wireless throttle base stations, then local relay panels assign blocks to throttles via 18 gauge drops.
Sheldon
My old layout, an 8x12 donut double tracked - well, I TESTED it by just hooking one pair of feeders to the DCC system, and trains ran fine (and all joints weren’t even soldered - none of the turnouts were soldered, just the joints between sections of flex track in between).
this Rail Size page from DCC Wiki says code 83 is the equivalent of 26g wire which has a resistance of 42 Ohm/1000ft
if Wayne attached power to the middle of his 260 ft run, the longest distance from the feeder is 130’ or 5.5 Ohms which would have a drop of 5V at 1A at that distance, only 0.5V for 100 ma of a more efficient motor, again at that distance. (half if connected at both ends)
maybe an 18g bus (6.5 Ohm/1000ft) is overkill on most layouts
And this points to another basic difference between DC and DCC.
Wayne is only powering one train at a time.
I am only powering one train per active block.
Not a whole layout of different operators…
My wireless throttles each have their own 4 amp regulated power supply that only has to respond to at most three or four modern loco motors in blocks 30 to 70 feet long.
Never any issues.
Sheldon
At what length of soldered track does voltage drop begin to occur on a 12-volt DC powered layout?
That’s correct, Rich, but do keep in mind that mine is not a block-type system, where more than one train can be operated independently from other ones also in motion.
This was easily accomplished with gaps in one rail, and a wire dropped to a simple on/off switch on the fascia - a foot or two of wire at most of those many locations.
My layout was wired with the common rail system outlined in the Atlas book, but not using the Atlas current-controlling devices. Simple to install and operate, and simple to trouble-shoot, too.
Running the dozen-or-so locomotives at one time was/is a game I play when my grandkids simply wanted to “see the trains run”. I’d put one on the track and they’d walk around the layout following it. While they were thus engaged, I’d place another loco on the track, and continue adding locos, much to their surprise, in the same manner.
When it came time to wrap-up the session, I’d simply grab one off the track as it passed, until we were down to just one in motion. At that point, I’d let the oldest or most-interested one run it to where I wanted it parked.
Two of them (3 & 6 years old) are still interested in the trains, but the others have pretty-well moved on.
Like my kids, all of my grandkids are respectful of the models - I let them touch certain things at certain ages, and let them run the trains, too, but they’re well aware of the fragile nature of most items, and are very considerate of those limitations.
As Greg pointed out, voltage drop is a function of distance and current, so with modern low current equipment, the rail is an effective conductor for a pretty long distance.
If I was building a DCC layout, I would use more power districts, lower current circuit breakers and not worry about all this feeder buss.
Sheldon
That is my solution to the voltage drop issue, more power districts and shorter sub-bus wires. But, I operate in DCC and my understanding is that DCC, as well as AC, is more sensitive to voltage drop than DC.
I might as well jump in and muddy up the topic.
I have 121’ of Atlas Code 83 NS Flex Track in a twice-around. I use Walthers 948-841 NS rail joiners. The 948-841 joiners fit extremely tight, none soldered.
I have two long blocks of 13’ (paralleled) the rest average 8’. I feed each block with #20 solid twisted pair (Bell Wire) from my control panel. All 15 blocks are homeruns to a DPDT center off toggle on my control panel.
My norm is a pair of very heavy E7s (34 oz each) at wheel slip draw 600ma or 1.2 Amps for the pair or a single heavy Cab Forward that draws about 580ma at wheel slip.
The max voltage drop I’ve measured is .6 volts using my Fluke 179 meter. I haven’t measured the actual length of each pair of #20 wires but I would estimate the longest at 20’. I do not use separate feeders for each section of Atlas track nor do I power the frogs separately.
Even running more than one train there will only be one train in a block at a time thus well under the max rating of #20 AWG wire.
