I know that railroads usually buid their yards double ended, since it is easier to run trains in and out from both ends of the yard. Does anyone know of any stub end yards that are used exclusivly for freight trains?
. Ira
. Ira
GTW’s yard in Grand Haven, Michigan, was stub-ended from about 1969 until the line was abandoned in about 1977. For all intents and purposes, it was operated as a stub-end yard even before then (I first started watching the trains there in about 1962, and may have seen the opposite-end switches used once). The first thing the crew would do upon arriving was make a drop of their entire train, including caboose, then switch the local industries, leave the train in the yard, and go down to the end of the main line and tie up.
I’ll amend that…there was one local industry that had a trailing-point switch for incoming trains–if they had cars for or from them, those would be spotted or pulled first, before they made the drop on the train.
CSX’s Eastside Yard in Philadelphia is functionally stub ended. The Baltimore-Jersey mains connect with the switching part of the yard at the West (Timetable) end of the yard. While engines can get out of the East end of the yard, it is to serve local industires through a connection to NS/Conrail. The original purpose of the yard was in yarding and dispatching trains to the Reading, only secondarily did it have anything to do with through trains. When a Westbound B&O/CSX train was to be originated ‘off the yard’ the train had to be shoved out of the yard and onto the Main tracks to depart Westward from RG Tower.
With the ConRail acquisition the former ConRail yard at Greenwich has become the primary switching yard for CSX in Philadelphia.
DRGW/UP “Walker Yard” at Pueblo - Now mostly mechanical and M/W long term storage. Not to be confused with the big MoPac/DRGW joint yard at Pueblo.
MacMillan Yard (CN, Hump Yard) comes to mind…Tried hiking thru the yard in the 1990s and came to dead end at the W end. Got a ride back out by CN police after briefly having handcuffs laid on me in the name of the Queen and a ticket to Highway 7 w. I think I paid the Queen 80.00 via mail.
Goodman Yard in Marion, IN, is stub-ended, because the PRR Panhandle line between Columbus and Logansport, IN, is largely abandoned. Still, it’s an active NS yard for locals. It builds and handles locals that access the former NYC/PC/CR/NS Marion Branch, running north and south between Anderson and Goshen, IN.
Commuter and other passenger railroads will often have stub yards. In freight service there can be stub yards, too, like at industries, mines, and the like. In some places stub yards are built because of the lack of space to be in and out alongside a main line or where it can be tied to a tail track at the other end with a return track someplace.
I think you’ll find that a lot of “SIT” (storage in transit) yards are stub yards. All they are is a place to store the cars until the industry needs them, so it’s not necessary to get out the other end.
I’m sure Houston Ed can provide plenty of examples. I found two in the Houston area, just by looking around. One small one is at N 29.74821 W 95.01199. There’s a pretty substantial stub yard at N 29.74672 W 95.09162.
Yards, when built, were built for a specific business purpose. As times and business change the original purpose for the yard may be obscured by it’s present day used or disuse.
The GB&W had a stub yard adjacent to the carferry loading slip at Kewaunee, WI. It’s now a lakeside park. AA had a small stub yard next to its carferry loading slip at Elberta, MI. That yard was probably for trimming the ship, as the main yard was double ended. That area is also now a park, although the turntable and roundhouse ruin are still there.
While railfanning near Provo Utah I found the old Clearfield Naval Depot that has been taken over by several industries. Lots of track and switches that run parallel with numerous buildings. A small classification switch yard was added next to the area. Found it on Google maps. Would like to model it when I build my big HO layout.
Larry,
Your fist yard is in the middle of the Exxon/Mobil refinery at Baytown a, private yard, and the second one is inside a company called VoPak, it is their storage yard, they clean, repair cars there, the facility is a storage/trans load/blending facility for petrochemicals, and one of the PTRA’s biggest customers.
Scroll down, south just past the east west railroad tracks, (PTRA Pasadena subdivision) and you will see two stub end yards connected by a loop, we drag in around the loop, both of these yards belong to Solvay, and are their private SIT yard.
N 29.716/ W 95.076.
Scroll east (left) and follow our main, and you go straight through some of the biggest refineries anywhere, including Shell Deer Park and their huge coke pile, N 29.7323 / W 95.1444, the yard next to that is Deer Park Rail Services, a private storage yard that “rents” railcar storage, also one of our customers.
If you want to see a really big SIT yard, look in Dayton, Texas.at .N 30.0047/ W 94.9055
Served by UP on the former SP, this is a big place, has 3 shifts working 24/7, those are all plastic pellets and PVC in those hoppers.
And, right down the street from my house,
Thanks to all. I can now feel justified in putting a stub end yard on the mountain division of my layout where the transcon line and the San Juan cutoff rejoin at Portola. The yard will service the industries on the mountain division. Would i have the general merchandise trains rom each direction (east and west) pick up and deliver cars to the yard or would I run a dedicated train from my hump yard daily?.
Rira
In model railroading the idea is that if you can imagine it, it can be done; if you can imagine it, it probably has been done on a railroad somewhere at sometime or will happen somewhere, sometime in the future. How many guys I’ve heard say, I did this or that then found out the old Forgotten and For Good pike actually did!
Yes.
Both are prototypically correct. Of course, with a stub yard, it may be easier for a train from one direction or the other to make the drop - unless you’ve still got a passing track in the mix.
Look at the SIT yard in Dayton…it is actually a directional stub ended pair of yards, split down the middle with a diagonal pair of switching leads, one end is for east bound storage, the other end is west bound.
Approximately 5000 plus car capacity when full.
As for the either or question, do both.
Have your hump yard run a daily turn to your stub or “local” yard, and have a switch crew work the industries out of that yard, bringing back the out bounds to make up a pull track for your hump yard crew to take back with them after they drop off the inbound daily turn.
The hump yard is near the east end of my Valley Division (it is on the side the center peninsula nearest the Mountain Division). Portola yard is on the other (east) side of the summit of my Mountian Division, so the turn out of the hump yard would have to cross divisional lines. Was or is this done?
The other option is to have the hump yard send the cars for Portola yard to the east end of the railroad at Medford and then send the cars to Portola… BUT since the train out of the hump yard would be passing Portola, this would be VERY inefficient.
Ira
Conrail had a stub yard at Hilliard, Ohio on the same route that was used mostly to store cars… I see its gone now.
Crossing divisional lines would depend on the era you model, but it was done, and today crews cross divisions all the time.
UP brings my carrier a twice daily yard to yard transfer, from Englewood hump to PTRA, and they take their interchange pulls back with them.
In real life, there are a lot of local union contracts that allow crews to cross division lines on the same carrier, some on an out and back single shift schedule, others on an out, stay a shift, and come back the next turn.
My hump yard has 3 arrival, 3 departure, 10 classification and all of the other tracks associated with such a yard. I used the book “North American Freight Yards” as my guide when designing it. It has very useful information on each of the yards, large and small, with drawings of the tracks for many of the yards.
Ira.
