Sugar Cube Speaker Recommendation for older Athearn Blue Box Locomotives?
Hi All, first post on these forums.
I have three older Athearn blue box DC locomotives I’m planning to convert to DCC using LokSound 5 Direct decoders. I’ve been trying to figure out which sugar cube speaker to use but there seem to be a ton of different sizes and shapes.
Has anyone here installed a sugar cube speaker in an older Athearn loco?
If it helps these are the three locos I have:
Amtrak FP-45 https://photos.app.goo.gl/aEvc4GGpdk1W9PAN8
Santa Fe PA-1 https://photos.app.goo.gl/zjBL5BUETTUYC9Gz9
Santa Fe SDP-40 https://photos.app.goo.gl/cVYFfFv8ve9TPC4q8
Thanks
What you need is one of these:
https://www.harborfreight.com/6-in-digital-caliper-63711.html
Then you can measure the space you have inside the shell, length, width, and depth, without interfering with any of the mechanism. And then get the biggest speaker with enclosure that will fit - in the case of sugar cubes, it may actually be an array of 2-4 speakers.
While I have never ordered from this company I think they have some good solutions for tight spaces: https://store.sbs4dcc.com/sugarcubespeakers.aspx
The Athearn blue box has limited space inside so a speaker inside the cab roof may be a good solution. Also remove that bonfire of a cab light and install LED’s for the headlight.
once you determine which decoder you wish to use, that decoder will determine what is the appropriate speaker ohm rating you require. Then space available will determine which size speaker will fit or suit the space available. I hope that makes sense.
if you need to don’t be afraid to cut out some weight to make space available.
Enjoy.
The shop that basementdweller refers to is called the ‘Streamline Back Shop’. They have an excellent range of products and their site is a goldmine of information.
Check out these two sections:
http://www.sbs4dcc.com/tutorialstipstricks/sugarcubespeakernotes.html
http://www.sbs4dcc.com/tutorialstipstricks/wiringmultispeakers.html
You might want to contact them directly to ask for their recommendations:
http://www.sbs4dcc.com/contactus.html
Good luck,
Dave
I actually have a digital caliper. I rarely use it so I forget about it. Thanks for reminding me. I’ll put it to use and take some measurements.
Happy Thanksgiving!
Funny you should mention Streamline Backshop. It was their large selection of speakers that prompted my post in the first place… [:)]
SBS also happens to be the place I ordered the decoders from. They should arrive early next week.
Happy Thanksgiving!
Chuck S. I would guess that you know about the BB’s motors needing to be isolated from the frame.
That copper or brass strip fasten to the underside of the motor that holds the brush in an makes contact to the frame.
Hi again Chuck,
TCS (Train Control Systems) has some excellent tutorials on decoder installations:
https://tcsdcc.com/installations/ho-scale
Scroll down to a bit to the Athearn installations. I haven’t studied them but there may be some useful information for you.
Dave
Sure do PC101. All three loco’s are going to be getting a complete overhaul.
Full disassembly, cleaning and re-lubrication of the gears, new motor mounts, removal of all corrosion, cleaning and polishing the wheels, full rewiring including replacing the brass power pickup strips with wires, replacing the 12v blubs with LED’s, adding additional lighting, adding hand rails and grab irons, and last but not least, Kadee couplers.
In short they are getting the works. I am looking forward to getting started on the project. Just waiting on a few more parts to arrive.
Thanks Dave.
I’m going to be installing LokSound 5 decoders, but I’ll check out the TCS info anyway.
After all, you can never have too much information. :slight_smile:
Well nicely said, you can never get enough information -:slight_smile:
Therefore, I suggest reading first “white paper” mentioned here, and then check the whole web site, it offers a lot of completed “drop in” solutions for different locomotives of different manufacturers, lot of them follwed by video. I did not buy from this shop, but comparison videos of factory installed speakers and it’s own speakers are impressive.
Regards,
Hrvoje
I unfortunately did not take pictures of the two I did for someone else (I on’y have one BB loco and it’s a long way from even getting DCC - plus it’s not a loco that matches anything my current prototype had). I guess I skipped photos because they weren’t my locos, silly idea I guess. Decoders and speakers were supplied to me by the owner, but as I recall there was considerable room under the radiator fans that still cleared the drive. It was 11 or 12 years ago, the speakers weren;t sugar cube style, just the typical ovals in a rectangular enclosure. One of them had dynamic brakes so I had to file a bit from the clip the held the DB housing on to get the speaker to sit flat, but that was it. Unlike the BB switcher I have, an SD or GP BB or RTR has a good bit of space under the hood once the old metal bar contact is removed.
Hrvoje,
Thanks for posting that info. The white paper is the best article I have read to date. I did not yet view the related videos. I gleefully added 2-4 micros in several of my HO locos, an apparent error. I will find it interesting to retrofit a couple with this fellow’s speakers.
Very cool. Thanks for posting.
To add more spice to the “soup”, now read this, it claims exactly the opposite concerning if small rectangle speakers should fire in or out: Small speaker comparison.
In any case, a lot can be learned from such articles/videos, but at the end - your ear is the final judge, what you prefer.
When it comes to OP’s original post, which sugar cube could be used, I researched a few days ago which small speakers to buy, I selected three/four (different dimensions) that I would like to test:
13 x 18 mm or 13 x 18 mm
10 x 20 mm
11 x 15 mm
I find the frequency response and sound pressure level of these speakers interesting, especially the first one 13 x 18 mm. The last one (11 x 15 mm) is probably more interesting for European locomotives, because there is sometimes not much space for even a sugar cube speaker.
Hrvoje
