Suggestions For Ho Turntable Motor
fHi I am having problems on how too make my Ho Turntable Motorized.I was hoping somebody here can tell me what too do on how too make the Track Part.Where the Gears would fit in line with the Track.Hope the Pic I posted witt attach.If not then I will email someone here and they can post it for me.
I read Bergie’s Topic how too Add Photos STill Did not Work,Yes this is a Homemade Turntable.
No I do Not Put my Birthday Etc too Join a Site I do Not Know About.Maybe someone here can post my Photos for me.
You will need to supply more information and/or post your photo to a webhosting site like http://photobucket.com/
Is it a home made turntable? If it is not, then the manufacturer probably has a motorization kit for it.
Fergie fitted a motor and gearbox a while back to his turntable, anyone know if he’s around
Believe it or not I’m still alive and kicking!
The following link is a good source for a motor but I must make the disclaimer that I am not endorsing these guys. They’re the only ones that i know that carry the motor and it works well.
http://www.allelectronics.com/cgi-bin/item/DCM-245/search/6_RPM_GEARHEAD_MOTOR_.html
The following pics should serve you well. Sorry I am not going to post them individually as I find posting pics too difficult in the “New and Improved” forum. Yes that was a dig!
http://www.trainboard.com/railimages/showgallery.php/cat/500/page/2/ppuser/5959
There was an article on the forum one time describing using a cheapo Atlas TT underneath another TT to drive & index it. The Atlas TT is indexed to 10 degrees. I use this setup myself until I can get my stepper motor drive set up & working. If your roundhouse is indexed to a different angle, the article went into detail about how to change the gear ratios to still use the Atlas auto-index feature. As you turn the TT it stops every 10 degrees for 1 turn of the gear. Neat. I 'm using my as an armstrong, but Atlas makes a drive kit. Tweet
One merely needs to google search for “12V DC gearmotor” and look through the results. First hit i got had a 4RPM motor as the very first listing. Gearmotors are very common, so it should be easy. A 90 Degree angled gearmotor may mount easier for you.
Or, how about this walthers turntable motor?
http://www.trainsetsonly.com/page/TSO/PROD/942-472
I’m looking at this one possibly for my own HO heljan turntable. I’m sure it could be adapted for other turntables as well. I’m not sure how good a system this is though since I don’t own one myself.
I da know…If you’ve got a FREE photobucket account its as simple as copy then paste! What could be more easier?
Your problem is simple. Where it says Turntable#1 above you are linking to a photo on your own computer. That computer is (hopefully) unavailable from the web. You need to store the photo on a web server and then insert the path to that server.
Something like this: [ img ]http://mywebsite.com/Turntable1.jpg[ /img ] {remove the blank spaces inside the 's
There are many web based photo hosting sites. I use my own server so I’ll let others recommend some.
Good luck.
Karl
can anyone find this, looks like a good idea, didn’t know you could change the gear ratios?
Say can somone here tell me step by step on how too post photos,without using PhotoBucket.Thank You
This forum doesn’t allow uploading of pictures to it, so therefore the pictures need to live somewhere else on the internet. Photobucket is just one of many places to use. If your ISP allocated you webspace, then you need to figure out how upload these pictures you want to post to your webspace. If your ISP doesn’t offer that feature, you can signup for www.geocities.com webspace… or one of a million out there. Once you have uploaded a picture there, you can use the regular forum IMG tag: [ img ]http://www.blah.com/~blah/blah.jpg[ /img] to post your pictures.
I suspect since you’re looking for a DIY solution that the budget is somewhat of an issue.
However, if you’re looking for a quality, simple to set up turntable drive, I recommend New York Railway Supply:
http://www.nyrs.com
I’ve been working on my turntable installation a little at a time over the last year and finished it up this week. The key to how any TT operates is to get things level and perpendicular, of course. But the drive part is a snap with the NYRS servo-step motor design. It is direct drive, so you just couple it to the shaft of your TT then teach it where you want it to go. No outside sensors or other fiddly adjustments are needed. There are other ways to set a TT up, but if it’s within your budget, the NYRS drive is a very good investment.
