Switch(back) connection to mainline or siding
was told on MRH that it doesn’t really matter
i’m planning on have a switch(back) track, U, to reach a # of spots (A-E) on building flats against the back of an 11" deep section of bench. switch(backs) are reach using a “tail” that can hold a limited # of cars.
i think it would require fewer moves if the switch(back) turnout is on the mainline instead of the siding.
Otherwise, the operator would pull all the cars out and push them onto the siding, then move onto the mainline and sort them into the needed order and need to put those cars onto the siding.
In the real world of railroading - you do what you have to do with what you have to work with. If there are geographical or ownership constraints on the location you do what is necessary to accomplish the task.
Referring to the term ‘switch back’ harkens to the early railroad engineers engineering solution to surmounting grades with a series of inclined planes to climb the grade with a series of switch backs up the face of the grade.
part of my motivations for doing this came after reading Lance Mindheim’s book How to Operate a Modern Era Switch Layout where is suggested it’s not the # of industrial spurs, but the # of spots.
What if you right click on the image, or press the Ctrl twice?
Yes, Mindheim shows situations where railroads even today have to move a car out of the way from a spot so another spot can be filled. I think of it as railroads want to lay as little track and turnouts as possible, (or make do with what already exists) because its often very expensive to add track. Easier to move a few cars than to build more track, but 5 cars is a lot for one spur, IMO.
You probably won’t have all five spots filled at the same time, so that can help determine the number of cars needing to be pulled and how long the tail needs to be. (The map looks like they got way with a short tail because not all spots typically had cars on them at the same time. And I don’t think its actually 5 spots looking at how it curves.)
I would think of your switchback as a necessity for the railroad if there were space considerations to navigate, like existing private property/buildings or a natural barrier like a body of water. The map looks like the railroad needed to work its way back to the buildings…probably due to space constraints.
Also, the “siding” tracks in the map would likely be used as a yard to hold cars and provide a place to place cars out of the way when switching the spur. Its actually a small double ended yard, IMO.
I personally don’t care for any type of plan involving these switchback type track configurations. Regardless of what the prototype might have to do, in the model world I’ve found that it might be fun to do a couple times, but after that it is a royal pain.
Anyway, concerning the location of the off the main turnout, I think I might add a turnout (or 2) so that you can go from V to T without going to U. This will prevent blocking the main during the sorting process.
Having multiple shippers on one track isn’t really that unusual, now or in the past. I have a book showing the layout of the NP in Crosby MN in the 1920s; it had two long spur tracks, each with 3-4 businesses (and the NP station) on it. Plus, in the Midwest and Prairie West, it wasn’t unusual for a small town to have a ‘house track’ running behind the depot with several industries (grain elevators, coal dealer, etc.) along it (although those were usually double-ended sidings).
However, I’ve always shied away (if possible) from switchbacks. I do recall reading (I think in one of John Armstrong’s books) that railroads didn’t like using switchbacks to serve a business, they’d want to go more direct. However, it did note that sometimes a switchback could exist where say a spur track came off one track of a double track mainline, and the railroad single tracked it later. They might leave enough of the removed track to allow serving the industry or industries on the spur. But I’d think that was pretty rare in reality?
We have an industry pretty much like what is posted at the top of the thread. But it gets better - the tail track isn’t long enough if the customer siding is filled. So you have to piece cars out a lot - and order DOES matter when spotting.
And even better - there’s also customer spots on the tail section of track that need pulled to get to the cars on the other end (A-B…E end)
Customer track; so it is what it is. Esp with older customers, you don’t always have super easy and simple setups.
It get even more “fun” for switch crew if there is a tank car still unloading (hoses connected) is spot “E”. Highball.
