In 1956 all the switches on the Cajon Pass line were hand thrown except for the interlockings at the entrances to San Bernardino and Barstow. The Aerotrain photo shows a dwarf automatic block signal governing the westward main line in the foreground (if you could read its number plate you’d see that it’s signal 553), but no switch motors.
It was only when CTC was installed after the big 1972 line changes that dual-control switch motors were applied to the mainline crossovers on the old First District of the Santa Fe’s Los Angeles Division… Many of those motors are probably still in service for BNSF.
The Details West part looks more typical of prototype installations I’m familiar with for CTC/dual controlled siding turnouts in the interior West, and is also based on a US&S design for an electric, as opposed to electro-pneumatic, machine. Here’s a close-up of a prototype of the Details West part http://home.comcast.net/~pugsplus/nw_ash_dcuss.html . Apparently the Irish Tracklayer detail is based on an SP prototype from the San Francisco terminal, and similar to others used on various roads (especially in the East), but you’d have to do further research to see if BNSF or AT&SF (the predecessor road through Cajon Pass) ever used something similar in that area.
Did you note the link is for an electro pneumatic? This would be the air operated version, not the dual control model that would be used Cajon when CTC’d.
I couldn’t find one of these taken near my childhood home in Houston when I was looking for it, but I found it just now while I was looking through my scanned photos for something else. There was one just like this (as I remember) on the Houston Belt and Terminal, installed by 1953 or so. I had electric switches on my Lionel layout so I knew what it was and I knew not to step too close to it because it could go into action controlled by someone somewhere else -who couldn’t see me-- with no warning…
This is on a crossover on a section of double track at Sinton Texas, taken about 2000.
