Is there any list of main road US tank engines (single frame locomotives without a tender). I know they were not very common on US RRs, but perhaps somebody put together some list.
(exclude please the portier, saddle tank, Forney and othe small logging locomotives or shunters and of course Thomas and his Friends [:)]).
The St. Clair Tunnel Co. had 0-10-0T’s that were used to pull trains through the tunnel prior to the electrification. After the tunnel was electrified, they acquired tenders and were demoted to yard service.
A website that lists all surviving steam locomotives in the US and Canada is www.steamlocomotive.com Locomotives are listed in several ways, i.e. wheel arrangement, state, builder, etc. It is a very good website for people interested in steam locomotives.
Any discussion about American Tank Steam Engines should also include the REUBEN WELLS.
An 0-10-0T when built in 1868, and after twenty years of service was rebuilt into an 0-8-0T. It was built to work on one of the steepest railroads in the US; The MJ&I RR (Madison,Jeffersonville& Indianapolis RR) in Southeastern Indiana.
When retired it was reworked at PRR Altoona Shops back into its original 0-10-0T configuration and placed for display in the basement of the Children’s Museum in Indianapolis-- Here is a link to the Museum’s Website and info on the Reuben Wells
Not trying to belabor the issue about Reuben Wells, but your mention of having visited the Locomotive in the Children’s Museum leads me to add the following link to a previous thread that discussed the environment and requirements for PRR’s Madison Hill ( A 5.86% grade). I thought you might also enjoy reading it.
unfortunately the link does not work. I still do not understand several things around this locomotive.
You wrote about a 4-6-0 engine with small attached tender.
In Steamtown there is a following description:
The latter was placed under the tank, which was of the water-bottom type. The rear frame, on which the tank was carried, was of steel, cast in one piece with the truck center plate, draft gear housing, rear bumper and tank supports.
What is the rear frame? What was cast in one piece with truck center plate?
