Hi, I installed a TCS WOW WDK ATH-3 decoder and it was working fine until I tried to follow the voice programming. Now there is no sound. Still runs forward and reverse. I reset to factory defaults - still no sound. There IS sound when using the voice programming just no prime mover, horn, bell or anything else.
I did reset it and nothing. But GET THIS - Turned it on this morning and the sound is back on! I don’t know what happened? If anyone has any ideas please post them.
I don’t like this WOW Voice programming. I need to find a TCS-WOW CV chart somewhere so i can program everything normally.
I have one WOW sound, and yes, its much different from the Tsunami’s I’m used too.
I didnt really care for the sound programiong either, unless it was to set the volume levels and minor things like that. I have always used JMRI for this kind of thing.
Now back to my experience, pushing F8 twice gets you to “light mode”, 4 times gets you to the “sound mode”.
I’m not sure how I done it, possible by using a Soundtraxx soundcar decoder in the consists, because to consist the sound car with the engine decoder to must release the brakes on the car and press F8 4 times.
Now, and for the longest time, the sound on the WOW works when my Digtrax Zephry shows that its muted, I guess I’m lazy, but I never worried much about it or how I got it to that point, but I do like the decoder.
You press F8 x4 in rapid sucession to enter audio assist.
“To enter , stop your locomotive on an operational track and press function button 8 in rapid succession 4 times. The decoder will start talking to you giving you a menu similar to a telephone answering machine. Just follow the verbal instructions to adjust or remap many of the sound options. When you have made a selection press 8 to save each selection and then press 0 to exit.”
They also have a chart to follow.
A single press of F8 will mute the locomotive.
Double press swaps between light and sound mode, but it should not affect the sounds playing already.
Did you start the prime mover? I cant remember if you have to start up the locomotive with these decoders or not. Guess its time to run trains.
