Not directly addressing the primary topic, but I think providing some pertinent background, here is a “potted history” of span bolster running gear.
As far as locomotives are concerned, span bolster running gear appears to have originated in the first half of the 1920s in American interurban practice. A non-exhaustive search shows that in 1924, Piedmont Northern used the B-B+B-B wheel arrangement, with articulated span bolsters, whilst in the same year, Illinois Terminal used B-B-B-B, with independent span bolsters. In some of these cases then span bolsters may have been associated with lateral motion trucks. There may well have been earlier applications. Span bolsters were also used for freight cars, in for example 4-4-4-4 and 8-8-8-8 configurations, but I do not know the timelines. Four-truck interurban locomotives were built until at least 1941-42, e.g. Piedmont & Northern #5600 by GE,
The NYC T class electric locomotives of 1913 and up had a single-frame B-B+B-B wheel arrangement, but it was not of the span bolster type. Rather the inner axles were rigidly mounted to the beams, with the outers in non-lateral notion trucks that acted as pilots to the inners. (1) One could say that it was more-or-less a 2-B+B-2 wheel arrangement but with powered outer trucks, although 2-B+B-2 itself did not arrive until 1921 (GE for Paulista, Brasil).
The solitary EMD (Winton/GE/St. Louis) model T (was it painted black?) transfer locomotive of 1936 for the IC had the span bolster B-B+B-B wheel arrangement, with as best I can tell, rigid bolster trucks.
Post-WWII GE used the B-B+B-B span bolster wheel arrangement, with articulated span bolsters and rigid-bolster trucks, for the VGN EL-2B electric locomotives. (2) Then it used the non-articulated B-B-B-B form, with swing bolster trucks, for the Alco-GE GTEL4500 prototype (3), carried over to the GE production machines.
In that time period, Brown Boveri also proposed various GTEL designs, including some aimed at the US market which had span-bolster A1A-B-B-A1A running gear, as well as a D-D. (4)
Overmod has mentioned the Westinghouse non-span bolster B-B-B-B wheel arrangement used on its solitary GTEL prototype. That was derived from a Westinghouse proposal for a homologous series of electric locomotives (AC and DC) that all used the same standard B truck with non-lifting lateral motion. The range went from B-B, through B-B-B to B-B-B-B, and most improbably to articulated span bolster B-B-B+B-B-B and B-B-B-B+B-B-B-B versions. (5) The single-frame tribo form – with extended lateral motion centre-truck - was by that time well-established, although not widespread, in worldwide practice (GE appears to have been first, with a B+B+B for Mexicano c.1924). The Westinghouse B-B-B-B was an extension of that. (In respect of the tribo form, the articulated body type was also known pre-WWII, but the semi-articulated body form was yet to come.)
The Baldwin STEL prototype for N&W had (non-articulated) span bolster C-C-C-C running gear.
In 1962, the UP proposed using (in fact re-using) the same GTEL4500 B-B-B-B running gear for its desired twin-engine 5000 hp diesel-electric locomotives. (6) It had to order prototypes from Alco and GE, who thus did use this running gear. EMD chose to build prototypes on its own account, thus got to choose, and developed its own D-D approach. There is some evidence that UP might have preferred B-B-B-B for the DDA40X, but not unexpectedly, that followed EMD’s preferred D-D approach. (7)
In the late 1960s, French builder CEM developed a span-bolster B-B-B-B locomotive for service on the African Outre Mer metre and Cape gauge lines. The B trucks were of the monomoteur type. Lateral motion swing links were placed between the body and the span bolsters, not between the span bolsters and the trucks. Also, I think for the first time on a span-bolster locomotive, the couplers were mounted on the mainframe, not the outer ends of the span bolsters. This locomotive, designated the 4B type by CEM, was part of a family, which included the 2B and 3B types. The 2B type simply used two of the B trucks with swing link assemblies. The 3B type had a single B truck, as on the 2B, at one end, and a span-bolster B-B assembly, as on the 4B, at the other end. This made it the most ersatz form in the tribo group, and probably the most asymmetrical of the asymmetrical wheel arrangement locomotives – certainly more so than the Hungarian and British C-B examples.
Next came the GE export BB locomotives, which also had the couplers mounted on the mainframes, then the (I think – and this is strictly a layperson’s viewpoint – very neat) EMD export arrangement described above by Dave.
The D-D wheel arrangement (with true D trucks, not D wheelbases in a rigid frame), an alternative to B-B-B-B, was quite rare. As best I can determine, EMD was the only user. British Rail designed a swing bolster D truck c.1950, (8) but in the event never applied it. Otherwise D trucks have almost always appeared in pilot-truck arrangements, such as 2-D+D-2 and B-D+D-2. Baldwin also proposed, but never used 1-D+D-1. There was a solitary Russian prototype diesel-electric (the so-called Gakkel locomotive) of c.1924, single-frame with the 1-C+D+C-1 wheel arrangement, so this did have a D truck (It was an actual truck, not part of the frame, but one could say that it was piloted by the outer 1-C trucks.) (9)
By the way, GE referred to the GTEL4500 and U50 running gear as B-B-B-B, not B+B-B+B, as used in some publications. Whether the latter is a railfan derivative , or change made by AAR I do not know. In the British Commonwealth wheel arrangement system, with which I am more familiar, it would definitely be Bo-Bo-Bo-Bo, no ‘+’ sign anywhere.
(1) See US patent 1026552.
(2) The reasons for this choice were provided in ASME paper 49-SA-7, ‘Motor-Generator Locomotives, Their Design and Operating Characteristics’, by Fox (VGN), Gaynor (GN) & Gowans (GE).
(3) See AIEE paper 50-77, ‘The Alco-GE 4,500-Horsepower Gas-Turbine Electric Locomotive’, by Morey (GE).
(4) See Railway Mechanical Engineer, 1946 August, ‘Gas Turbine locomotives’, by Giger, p.394ff; also Brown Boveri Review 1945 October-November ‘The Brown Boveri Gas Turbine Locomotive’, p.353ff.
(5) See AIEE paper 48-54, ‘Electric Locomotives with Identical Basic Components’, by Brecht & Kerr (both Wemco)
(6) See: UP Miscellaneous - donstrack
(7) The span bolster possibility was mentioned in Railway Locomotives & Cars 1968 December in an item ‘Two-engine, 6600-hp Locomotives for UP’, pp5 & 6.
(8) See IEE paper #967, 1950, ‘Mechanical Design of Electric and Diesel-Electric Locomotives’, by Cox (BR).
(9) See Railway Mechanical Engineer 1927 July pp.435-437.
Cheers,
