Why is it, that when I reply to a post my entire message’s formatting seems to get removed? That is to say, all the paragraphs and double spacing and even my signature (name only) get re-formatted into one paragraph? Are there settings I need to adjust? Help! Brad
I noticed the same thing. I have to manually insert a space tag between my paragraph and name.
Jim
What software are you using? I don’t have that problem at all with IE6 or IE7.
Every time I hit the Enter key, IE inserts a blank line before the next paragraph or at the end of the post, like in this message.
I am using W2K & IE6. Enter works to compose the message and then changes in preview panel to this. If you notice a lot of posts are doing this. Jim
I’m having the same problem. When I go to make a reply, all I get is a Plain Jane reply box with no formatting tools. All it has is post and preview. I have to manually insert break tags < br /> at the end of a line and end of paragraph tags at the end of a paragraph < p>< /p>. I thought it was due to my computer. I’m running W98SE and IE6, SP1. I tried it on my neighbors computer (Windows XP, IE7) and it’s doing the same thing. Mine started doing it about 3 weeks ago. I checked all my settings, they’re all the same as they were 6 months ago, and everything worked fine then.
I noticed it around the same time Jeffrey did.
Jim
