I have a bunch of feeder wires to solder to my track. I have a temperature controlled soldering station. What is a good temperature to use? Thanks.
Mine is an older model that doesn’t have an LED readout, it just has a knob, marked with a range from 28 to 44 which is supposed to correspond to 280C to 440C. The range 31-41 is marked in green. For most soldering I have it around 38, when soldering track I turned it up a bit to 41.
Some recommendations say those are too high, especially for leaded solder (I don’t use that lead-free rubbish - just don’t stick it in your mouth and wash your hands when done), but I have yet to damage a PCB or component, not did I melt any ties when soldering track together. And the original tip that came with my system is still usable, some 13 years later. I DO turn the knob all the way down if it will be some time before I am ready to solder the next joint - for example, if I just got done soldering two pieces of flex track together (I do this at the bench before I lay the track), I’ll put the handpiece in the holder and turn the knob to minimum while I get the next two pieces of flex, some joiners, put flux in them, and connect the pieces. Then I turn it back up, wait for the light to go out (a couple of seconds at most) and go to work on the next piece. Or on a PCB, say I’ve installed all the resistors and soldered them, now I am going to install say all the capacitors. Turn down the soldering station, then populat the board, and when ready to start soldering them all in, turn it back up.
There are fancier (3-4x the cost) stations that have sensors in the stand and dial it back automatically. That’s OK. My way works fine, and has for the over 13 years I’ve had this one.
Thanks, Randy for your reply. My station has a dial that you can set between 350 and 800. I want to use enough heat so I don’t stay in contact with the track too long, but not enough to mess things up. I guess I will just experiment and see what happens. [:D]
Jack
My WLC100, 40 watt soldering station has 0 to 5 numbers. I set it at 4 and use a plated wedge tip.
If you have not done this yet, practice on scrap track first. You should see a smouth flow of solder.
I used a burnish tool from Micro Mark on the spot on the spot on the track, first.
Does it have a readout that indicates the actual tip temperature when set?
The selected tip temperature will vary with the type of solder, and you will want at some point to research the different types of solder including very-low-melting types (which I think have validity for the kind of work you’re contemplating). Often the places that specialize in different solders and equipment will list the suggested settings.
The selected tip temperature will also vary depending on the heat-transfer characteristics of what you’re soldering. Remember that the melting point of the solder is not the tip temperature you dial in. Solder joints have to be heated by the joint substrate – the iron is just a convenient heat source you can apply to get that done. In some cases the tip temperature has to be set many degrees ‘hotter’ than the temperature of the actual point where the solder is to be applied to melt, and in any case you need extra heat in the joint to ensure all the solder goes to liquidus as it will absorb some of the heat in melting fully, so anywhere from 10 to 40 degrees F above the nominal ‘full liquidus point’ given for the solder before the solder is applied might be a starting place. (On occasion I ‘cheat’ and use one of those point IR thermometers to see just how hot the ‘target area’ is getting, but it can be hard to work the thermometer, the iron, the solder, and any ends all at the same time… note that this kind of thermometer offers a pretty good way to ‘calibrate’ tip temperature to dial position if you want to mark a few positions on the dial for ‘quick access’ using different kinds of solder or different classes of work…)
Something you may not know involves the use of ‘eutectic’ solder. If you’re concerned with quick setup time, this type of mixture ‘freezes’ from
I have used a roll of quad eutectic silver solder I bought from Amazon some years ago. Seems to be the best type of solder I have used over the years but pricey.
I started soldering around 1956.
One challenge is to not melt ties. I used HO code 83 nickle silver track and solid 22 AWG feeder wire.
I was using a Weller gun (overkilll re: heat supply) before I had a soldering station so put my ties at risk. I used an alligator clip attached close to the feeder wire on each side to moderate the rail temp near the connection point. There are likely better ways. It helps to tin the wire and the rail contact point first, so the actual connection is quick.
Thanks for all your answers!! I will keep this information in mind as I start soldering the feeder wires next week.
Jack
They key is an iron with enough heat capacity, and a CLEAN tip to transfer heat to the poitn of contact quickly, without having to hold the heat on so long that it can spread through the rails and melt the ties. If you have to hold the iron against the rail for a minute to get solder to melt, you’re doing it wrong.
For soldering to track I set mine to 750. I go in hot and fast, get it done quick, and get out.
-Kevin
Some conventional wisdom previously mentioned here by others:
Remove the ties (2 would be sufficient) from the attachment area, as for joint soldering, then gently shave the tops and reinsert them laterally.
Or make ties out of relatively refractory material like PCB for the locations needing soldering.
Use of proper heat-sinking (the various wet-towel sort as well as alligator clips, pieces of motor-cooling block, etc.) is always a plus, the issue here being that you’re heat-sinking something directly below the Area of Work, which could be handled by something like a metal typewriter shield with a slot cut for the feeder wire.
In my opinion if you go for the idea of pre-tinning the wire and rail, use eutectic solder exclusively. The careful part then changes to how you accomplish the ‘tinning’ to the rail – you can with eutectic carry the solder to the joint on the wire, either as a chip or heavy ‘tinning’, and a good joint will be achieved just by bringing the solders to mutual liquidus…
Note the point about the clean and well-tinned tip. In my opinion, if you do not have something like a bronze-wool tip ‘cleaner’, invest a couple of bucks in one. And then use it religiously. All the temperature-controlled heat in the world does little good if you can’t transfer it cleanly to make the joint.
My advice is to practice, practice, practice. If you do it a fewe times, you will get a feel for it and not melt ties, even without removing them or subbing out PCB ties. The installing PCB ties adds some interesting other ways to attach the feeder wire - but you do have to solder the rail to the PCB tie and at some point there will be a PCB tie next to a palstic one - unless you handlay all you track on PCB ties (my attempts to hand lay turnouts failed from not getting good frogs and point blades - so hand laying sone straight/curved track is something I may do just for a small part of my layout - seeing as I have a huge bag of ties and all the necessary tools).
What Overmod suggest is what drives me nuts in many MR videos - because usually what they show is 60/40 solder being used in that manner, which is NOT eutectic. Using a eutectic solder like 63/37 or some other alloy greatly lessens the chances of getting a cold joint when you aren’t first forming a solid mechanical connection and happen to be a bit shakey like David Popp. I’m all for giving yourself a challanege in order to improve skills, but at some point it becomes a case of use the right tool for the right job.
ANd those who are just working up to soldering skills - notice a recurring theme in every post frome those of use who have been doing this a long time? CLEAN TIP. My soldering station came with the bronze wool cleaner, and like the station itself, I can’t believe I didn’t get one years before I did (though they used to be a lot more expensive - so as a kid I made do with the 60 watt fixed heat iron we had, when the 250 watt gun was too big. That iron had a relatively massive tip, too - but I built a computer kit without melting anything or ruining the PCB, and 40+ years later I still have ot and it still works.
But the key is and always has been cleanliness. A bright shiny ti transfers heat quickly. A dull oxidized one (I’ve seen people trying to solder with nearly black ti
In the interests of complete fairness – and running the risk of hearing cursing 'thru the ether about another long and complicated arcane post about soldering – you can file, machine, or polish the tips all you want, as long as you treat them right during and after the operation.
In the ‘bad old days’ of copper and copper-alloy tips, the tacit understanding was that as soon as you got done tinkering or filing or reshaping, you would immediately clean and then flux and tin the tip. And I mean ‘immediately’, not a few seconds or minutes later. Oxidation does form quickly on a clean copper surface (even faster on one with a certain range of surface-finish roughness) but the layer of ‘tinning’ probably helps dissolve some of the oxide away from insulating the transition between copper and solder alloy, and very little oxygen will subsequently reach the tip copper itself. It is also relatively easier to ‘rework’ the copper tip (by removing the solder, machining as desired, and retinning) than to mess with plated or partially-plated tips.
Of course you have to pay careful attention each time you make a joint to clean the tip and then retin it to full brightness … each and every time … which is less critical with a plated tip. But read on…)
The ‘ultimate’
Maybe worthwhile if you have an antique and have a use for it - like soldering frames for stained glass. But with the price of tips for a modern iron - and a good reason to avoid complete no-name ones which may not have any spare parts available - seems better to just treat it properly, and when it finally has reached end of life, just repalce it. My original is more than 13 years old and still fine, cleans up to a nicy shiny surface. Another advantage of a temperature controlled station - it reduces the oxidation rate and the tips last longer.
The best thing I did was to buy a soldering station. The next best thing was to buy a bundle of used track at a train show for a dollar to practise soldering on. It is amazing how you get a feel for doing it fast and neat with a little practice. Even today, if I am going to solder track I grab some crap track to warm up on if it has been awhile.[C):-)]
Hot therefore fast gives me the best results.
