Testors Dullcote - Okay with Acrylics & Solvent based Paints?
I am trying to find out what paint types you can use with Testors Dullcote.
Can it go under & over Acrylics?
Same question re solvent based paints.
Thanks
Tanked
DullCote has some magic. It goes over everything, solvent based, water based, acrylic, decals, and just works. I have once tried a can of clear satin somthingorother and it crinkled my decals. I’ve stuck with Dull Cote ever since.
Thanks.
What about 'under"?
I vaguely recall reading somewhere that someone liked to spray it over shiny new plastic freight cars as a ‘base’ for weathering.
If that is the case, could you put acrylics & solvents on top of it?? - (I guess so since you can spray over it).
Tanked
I have used Dullcoat for a long time on anything you might imagine, and never had an issue with it. It covers oil and acrylic based paints really well, and I have used it on rolling stock trucks to dull the shine and they look quite respectable as a result. I have also mixed it 50/50 with Glosscoat to give a semi-gloss finish to some projects.[C):-)]
When weathering you always start out with dullcote. Always. You can put acrylics & oil over it just fine. As for solvents, you would need to airbrush them, or carefully drybrush. Otherwise you run the risk of eating through the original layer of dullcote.
I have used Dullcote forever and it truly is magic!!!
I’ve used it under, over and with all sort of paint and have never had a problem…
However, it should be noted that Dullcoat being a lacquer can and most often will be affected by alcohol, making a whitish, very dull, bleaching, ash looking type of “thing”. This is actually good in some weathering projects I’ve done, but should be noted as “Do not over-coat with an alcohol base” if you don’t want that bleaching!
The solution for the bleaching is to just give it another coat of dullcote to neutralize it.
