Do you mean Tenshodo Challenger???
It’s cool!I had to re-solder the wire that plugs into the tender and add a brass draw bar extender as well as. Kadee #5 coupler .I painted the tender flat white ,put on vinyl letters and then painted it black.Let it dry and then peeled off the vinyl UP lettering.
There IS a manufacturer called TETSUDO. Perhaps this is what the OP is refering to?
TENSHODO was certainly another player as well.
Good Luck, Ed
“Testudo Brass” means “Brass Tortoise” - you sure about that
Well the only markings I found on it was a brass gear plate with Tetsudo stamped on it .Has a large motor that looks like it came from the '50 s and sounds like a coffee grinder but it runs very smoothly even at low voltage
Doesn’t look like Tenshodo made this.
See my prior reply:
Good Luck, Ed
Tetsudo was short lived compared to some of the others. I think they were gone by the early 60’s. Some of their models aren’t especially valuable, but others can have a very high price tag due to their extreme rarity.
Tenshodo is actually still around. They just don’t make US models anymore.
Well I paid less than 200 bucks so I am happy!
