The 11 Myths of Model Railroading
#1 – Zero maintenance layout (2200 sq ft layout) – You can’t maintain a large layout by yourself
#2 – DCC 8 amp boosters and welding engine wheels of the engine derails
#3 – Track Cleaning – Never again!
#4 – Reverse Loops – Using a toggle switch with DCC
#5 – Not removing ties on flex track
#6 – IDC connectors - 3M scotch locks/Suitcase connectors for track wiring-NEVER
#7 - The Rolling Stock Truck Tuner tool & why do you need one
#8 – Soldering Track Joints
#9 – Homasote Expansion vs Wood
#10 – DCC and you have to modify the turnouts – YOU DON”T
#11 – Homasote Cost – making a mess when cutting – You Don’t have to make dust when cutting
PLW the MRR Myth Busters – #6 - The Myth is:
You do not need to solder your track wires (Using IDC Connectors)
Only if you want to have problems with your electrical system later on!
The IDC connectors will work for a while but in an environment where moisture and humidity is high (basements – garages) they begin to cause problems.
We used them on our club Lionel display (located in an old basement) and had the trackwork up for almost 10 years. We had use #12 stranded buss wires and #12 drop wires. The track we used was Gargraves and most of the #12 drop wires were soldered to the rails. The IDC connectors were used to connect the drops to the buss wires. We had the proper Scotckloc connector for #12 wire and they worked well for 5 years.
We then began to notice that the trains would slow down on certain sections of track and were not sure why. An inspection of the wiring showed nothing wrong and in the process of checking the wiring the problems seemed to go away. While this was OK it did not really explain why the problems even showed up.
Then a different section of track began giving problems. We had the layout set up blocks using industrial toggle switches and it wa
