In the June 2010 issue of MRR, there is an artice titled, “13 Tips for Freight Yard Operation and Design”.
Tip #10 is to include a drill track off the main line. Fair enough! Then, Tip #12 suggests direct access between classification tracks and the main line and includes a diagram. The diagram illisustrates the connection between the classification yard and the main line. It shows an arrival-departure track but no drill track, although the extension of the arrival-departure track beyond the yard ladder access track from the main line is referred to as the “switching lead”. Is the switching lead and the drill track one and the same? Is the extension of the access-departure track beyond the yard ladder access track considered the drill track or switching lead?
On my layout, I have a double main line and an access-departure track, all connected by crossovers which continue as access tracks into and out of a double ended yard. My yard consists of 5 “classification tracks”, if you will. I use the first three tracks to classify cars, the fourth track serves as a caboose track, and the fifth track serves as a “roundaround” track for the switch engines to reach either end of each classification track. I am probably not using one or more of these terms correctly, and my layout is nowhere near prototypical, but I wonder if it passes at all for an accurate representation. And, do I correctly place the approach-departure track and is the extension of the approach-departure track beyond the access track to the yard ladder considered a switching lead or drill track?
Here is a very crude, and highly compressed, diagram of my yard. The blue and red tracks are the mainline, the green track is the approach-departure track, and the orange tracks are the yard tracks. The black tracks are the crossovers.
