I recently bought 7 undecorated Walthers Mainline Passenger cars, and I plan to purchase 5 more, all of which will be spray painted to reflect the two color schemes used by Monon, red and gray and black and gold.
That means that I have to remove the roofs which included molded on “glass” windows, to paint the body sides. Reading about how to remove the roofs is nightmarish.
Two relatively recent forum threads tackle the issue and can be found here:
My First Walthers Mainline Passenger Car https://cs.trains.com/mrr/f/88/p/249188/3024261.aspx#3024261
How to Open Walthers Mainline Passenger Cars
https://cs.trains.com/mrr/f/88/p/261241/2938744.aspx
There are also two relevant YouTube videos:
The Walthers Demo
https://www.youtube.com/watch?v=GWaJ6QpKDE8
Keith Turley “Twist”
https://www.youtube.com/watch?v=cr2A-QrqiPc
In theory, you hold both ends of the passenger car and twist the ends in opposite directions until the roof pops off. [(-D]
Lots of luck. After an hour of trying, I initially gave up.
It does appear that somewhere along the way, Walthers changed over from “tabs” that hold the roof against the body sides and break easily to “biscuits” that protrude off the roof assembly and fit into grooves on the body sides, and these biscuits do not break. So, much more force can be used to twist the opposite ends of the car body without fear of damage.
Once I got the first roof off after about 90 minutes of struggle, I was able to closely examine the structure of the roof and body sides. It was then that I realized that simply twisting the two ends of the body back and forth in opposite directions was counter productive. For every twist one way, the next twist the other way simply applied force in the opposite direction, tightening what was just loosened.
The cor
