Here’s a video showing onne of the most distinguished trains of the North East, the Tropicana Juice train. The Route seems to be Former ACL ‘Sarasosta Branch’, then the ex ACL main up untill Richmond, the former RF&P, Washington Belt Line (that’s what I call it) and finally, the ex B&O/CNJ. For a hotshot, it doesn’t seems to be very fast (60 mph maximum)
I see it a couple times a week and it never does seem very quick. Its actually slower than a lot of trains that go through, but…everything seems to be roughly the same during the day and much faster at night.
I see the Juice Train passing through Richmond often. By the time it gets to the Staples Mill Road Amtrak station area it’s doing about 35 MPH, although sometimes it’s stopped there as well, I assume awaiting clearance. North of the station it typically runs as fast as track conditions permit.
Here’s a new wrinkle: It used to be “All Tropicana, All The The Time!” Now in addition to 35 to 45 Tropicana cars, there’s anywhere from 20 to 30 container flats tacked on the tail end, sometimes as many as the Tropicana cars.
At her old job here, Lady Firestorm had to time her commute just right or risk being help up by the Juice Train at the Hungary Road grade crossing. She wasn’t held up that long, it usually only took about two minutes to pass. She didn’t mind the hold up all that much, it’s a fascinating train to see.
The “juice” now runs combined with a block of Orlando pigs to and from Florida. When you see it passing Greendale station, it’s observing the 25mph max authorized speed for freight in Richmond terminal. Once it is north of Greendale interlocking, the maximum authorized speed for that equipment is 60mph on the R.F.& P.
I was a conductor for CSX based out of Wildwood, FL between 2001-2002 and would work the Juice Train every now and then. Nice easy job and it brought out all the rail fans as it ran through the Wildwood sub during the day. Never traveled vary fast due to all the speed restrictions. It always had the newest power so the cab was air conditioned.
I’ve been seeing both a florence and a Baltimore subdivision ETTs and the maximum permissible speed is 60 Mph for general freight, wich seems to be the case. One curiosity : despite ATK trains now being slower than their ACL conterparts of yesteryear (79 vs 85/90 Mph, or even 100 between 1955 and 1957), route times don’t differ much in certain areas (especially Rocky Mount to Petersburg on the Northbound Carolinian). Maybe there are less speed restrictions now?
Typically it doesn’t go home as a unit. After unloading the cars go back as part of regular freight consists, several to the train.
Sometimes they come home with more graffitti on them then they go north with. The “artists” find those big white sides an irresistable canvas. So much for railyard security.
Actually, for the past decade or so, the juice cars have travelled back to florida as a unit. Years ago they were sent back on the 109, later 409, mostly as the rear cars of the train. They started running as a seperate train, 141, later 741 at least 10 years ago. There was a short period of time during which a smal block of “hot cars” were added to the rear out of north jersey. You had to look over your paper work carefully when you caught one of these blocks,as often the cars in this block were restricted to lower speeds than that allowed for the juice cars. As I stated in an earlier post, the juice cars are now combined with a block of Orlando pigs as train 121 or 141. You may occasionally see non Tropicana cars in consist. These are cars in Tropicana service, filling a temporary shortage of their own equipment.
From what I’ve seen, and mind you I don’t see it all the time, the number of Tropicana cars seems pretty consistant, up to but never more than 45 cars max.
Just a comment on timing. 48 hours is very truck competitive. For a solo driver this would usually be sked’d for a 3 day run(500 miles a day , 1162 road miles)
Most of what tropicana is looking for is consistancy. ie It gets there on a reliable schedule. So it can be 2 or 3 days in transit. Juice is not real time sensitive like lettuce or strawberries, and has a shelf life(if kept refrigerated) measured in weeks not days.
