The "N" Crowd
i was going to say it looks like a alco b/c of the large radiator fan in the rear, but i think fairbanks morse also had a large radiator fan if im not mistaken
If memory serves me correctly this was a Wabash Railroad branch and was spun off by N&W sometime in the mid-80s. Model Railroader did a A Railroad You Can Model feature on this branch and then included the article in one of their Railroads You Can Model dedicated publications, whether in Volume 1 or 2 I cannot say.
It seems to me that this branch came off of the Wabash main at Centralia and ran south(?) to Columbia; there was a major switching location somewhere about halfway between the two. These old A Railroad You Can Model incorporated some interesting trackplans; the one associated with this branchline impressed itself enough on me that it has stuck in my memory over all of these years.
nscaler711, in one of your previous responses you mentioned that you were very unhappy with Missouri because of the lack of hobby facilities. The only thing I know about Columbia is that on two occasions - twenty-eight years apart - it was a very convenient place to fill up my gas tank, and that it is the home of Mizzou. I know that it is not the biggest bulb in the chandelier but I find it difficult to believe that there is not at least one hobby shop of some substance in town, whether they handle N-Scale or not. Could you perhaps not preva
I used to have an RSD-15 in Union Pacific that looks alot like this one. If I remember correctly, it was offered by Life-Like. Instead of universal joints, it used springs from the motor to the gear tower.
Craig
I finally took some pictures of my layout today. So here they are
This is my coal mine I have yet to put in the trackage going up there as the weather has been bad and I can’t get out the saw to cut the wood to get there
hobbytown usa is the only one in columbia. also where did u get your info on the railroad?
Thanks for the help,that gives me an starting point,this engine is a real long one and has drive shafts insted of springs,It is allmost twice as long as my Kato RS-2or3 it is also an six wheel drive.But you my be right.
JIM
NS2591,
Wow nice progress, I can’t wait to see it finished!
Craig, now that I take a closer look at things this does appear to have CC trucks instead of BB trucks and this identifies it as an RSD something or another. For some reason or another I picture an RSD15 as having a longer short hood than this unit appears to have but that could simply be a perspective problem. I understand from another post on some forum - don’t remember just which one - that Atlas once made a “poor mans” RSD12 by slapping CC trucks under an RS11 body shell. Somebody else - Life-Like(?) - may conceivably have done this also. This unit does have a steam generator, something I had not noted before. I am not certain whether that might be an identifying feature or not.
nscale711 -
The notched hood at the numberboard location on the short hood is a signature identifying mark of an ALCO locomotive.
Note: I don’t know whether anybody caught this before I corrected it but this locomotive originally had a “short head”. Hee-Hee-Hee-Hee-Hee!!!
Looking forward to seeing more of this as it develops. Keep us posted by all means.
I’m no good at identifying engines. I just love to watch them roll by.
I did go to railpictures.net and noticed that there are pictures of RSD-12’s and RSD-15’s.
Of the high hood engine pictures, I can’t tell the difference between the two.
Craig
Back in the '60s. - that’s the 1960s, not the 1860s; I’m not quite that old - the '70s, and maybe even into the '80s Model Railroader magazine ran articles on A Railroad You Can Model/A Branchline You Can Model/A Shortline You Can Model, etcetera, etcetera, and soforth. I distinctly remember that one of the railroads featured was the Wabash Railroad branch from Centralia to Columbia. There was a community in between the ends of this branch which provided additional switching opportunities. I am almost certain that this was featured in the mid-60s as it was still being referred to as a “Wabash Branch” as opposed to an “N&W Branch”. These features always had distinct location features accompanying them as well as suggestions as to how these location features could be incorporated into a layout. As I stated earlier, I was impressed enough with MRs coverage of this branchline that, when you mentioned the line to Centralia, bells went off in my head. As soon as I get my MRs out of hock (read: storage boxes) and locate this article I am going to review it with a potential for development in my new/to be designed layout. Being a freelancer I am certain I will rename the locations and reconsider the industries but, even with that, I can still capture the essence of this branchline.
I am almost sure that Kalmbach/Model Railroader incorporated this layout in either their Railroads You Can Model or More Railroads You Can Model compendiums. I do not own either of those books because they are basically a rehash of articles from the pages of Model Railroader.
Dewayne,
That appears to be a Climax. Like many geared locos, it was used mostly for logging.
http://www.gearedsteam.com/climax/climax.htm
-Tracy
Finally got through all 40 pages. Took the better part of two days, though.
I’m currently working on a small switching layout (36"x9") until I get the basement cleaned up. I have hand layed the stock rails of the 5 turnouts with ME code 55 rail and layed atlas 55 flex for the rest. I’ll be painting the track and ballasting before I add the rest of the turnout trackwork. I should take some more current pics. The bottom of the pic is actually the back of the baseboard, and I moved the middle spur on the right to be parallel with the one below it. Those two spurs will serve a furnature factory (each spur holds 2 50’), while the spur on the opposite corner will be for a freight-transfer building (that spur can hold 3 50’s or 2 40s and 2 50’s). If I keep the track going to the very edge of the baseboard, the short end of the runaround track can hold the engine and a 40’, while the runaround track will only hold 1 car. Lots of switching goodness.
When I’m able, I’ll continue work on my larger layout (9’x5’ L) of the Aberdeen area worked by the Puget Sound and Pacific shortline. (a subsidery of RailAmerica). BTW - the layout pictured is a little different than how I layed the track. Instead of the switch at the corner of the L-benchwork I connected the back track with the staging on the right. (The track will be disguised as an abandoned lumber yard to hide the continuous loop.) The turnaround loop on the left end of the layout actually matches the prototype, so they can haul long grain trains to the port and back.
Also looking forward to trying to convert a GP9 into a GP10 and custom paint it for the PSAP.
-Tracy
Puquak you have got to post your process on your geep project b/c i want to do that too heres a photo of the loco i want to kit bash
http://www.rrpicturearchives.net/showPicture.aspx?id=215462
http://www.rrpicturearchives.net/showPicture.aspx?id=216092
heres a shot of they’re second loco
http://www.rrpicturearchives.net/showPicture.aspx?id=215464
711,
Unfortunatly that project is in the distant future. Knowing that I won’t be doing it for a while keeps me from getting too nervous about it. [(-D]
-Tracy
To Dave Vollmer, (or anyone else that can help)
I noticed that you kitbashed a Walthers New River Mine to make the one on your layout and I would like to do the same thing on my pike. Was it a difficult kitbash or is it something a relative beginner can do? Did you follow any plans or did you just go by what looked right? If you can give me any information or pics I would greatly appreciate it. Thanks in advance.
I followed an article Jim Kelly did in MR a few years ago. He kitbashed the HO version as part of the Turtle Creek Central mine branch extension in the April 2005 MR. The plans for that kitbash work in N too. I also photocopied all of the walls and built the kitbashed mine from the photocopies first, so I could get the measurements perfect before I started cutting up the walls.
It didn’t sem like a difficult kitbash to me, but you need to take your time and be careful. Remember, measure twice and cut once! I think anyone who’s ever assembled a Walthers kit can handle this kitbash.
Here are pics of mine:
Thanks for the reply Dave. Do you know specifically what issue it was in? Is there a Kalmbach book that explains the kitbash in more detail? Sorry for all the questions, those pics gave me some great ideas. Thanks again.
You’ll have to go back and read my reply again. It tells you what issue. I even looked it up for you.
[D)] Okay thanks again. I guess the pics at the bottom caught my eye a little too soon. BTW thank you for mentioning the photocopy idea. That will probably save me a few huge mistakes!
It’s kinda funny how it’s in the April 2005 issue, that’s the month before I started getting MRR magazine [banghead]
