Hey folks. Because of the size of my N scale layout which is only about six and a half feet long and three feet wide, I’ve gotten into a habit over the years of pulling no more than up to ten cars per loco - maybe twelve at the most if the loco is powerful enough to handle it. In doing research I’ve found that there were actually a lot of short trains back during the steam era, especially on branch lines. I have however seen twenty five cars or more pulled on larger layouts by both double heading or having a pusher loco on the rear.
I would think that most of us do. In comparision to prototype trains most model railroad trains haul a lot less rail cars.
My passenger trains are usually about 5 or 6 cars and most of my freight trains are about a dozen cars in total.
As you indicate it would look strange to be running trains that are about 3/4 the length of your total mainline trackage. In many places there would be only a foot or two between the end of the train and the locomotive pulling the train.
On my ISLs I limit the cars on the interchange-some days 8 cars arrived other days one while some days the only switch moves is to pick up cars at one or two industry and take 'em to the interchange.
All the layouts that I operate on all have limits. However, the limits are not derived from the power of the locomotive but from the length of sidings. One layout is 6 cars because the shortest siding is only 6 feet long, another 8 cars, another 10 cars, and yet another is not a car limit but any train 22 feet.
I have a long 40’ 2% grade. My BLI 2-10-4 can pull 11 Rapido coaches up it without breaking a sweat. My BS 4-4-0 can handle 5 cars and I have two Atlas Trainmasters that still have not found their threshhold. I think I have had close to 60 cars behind them and they had little problem.
Depending on my mix of cars the limit is about 45. That is due to the track length at the only area where two trains can pass. I’ve gone as large as 107 cars as a demonstration to a friend, that was with 4 six axle Athearns in the lead and a pair of mid trains. Got that monstrosity around the layout once till the mid trains stalled breifly and caused about 20 cars to stringline and hit the floor. No more.
I have a fairly large HO layout. 35 x 13. Still, I limit trains to about 5 feet long. Usually about 7 modern grain hoppers or 10, 40 foot aggregate cars. I think the trains just look better at that length.
That visual appeal is why I chose a shortline as the theme of my layout. The train lengths that look good to me suit a shortline better than a class 1 railroad.
I model N-Scale as well, but only about 1/4 of the way laying track. With operations in mind, I’ll hold to a typical 10-12 car limit due to the sidings I have planned on the various switching locations on the layout.
There are several limits on my layout. I have the standard gauge limits marked in staging. It’s a length limit, not a car number limit. I have a maximum length, which applies to passenger trains and through freights. They usually don’t get in tight situation because they’re moving own the line. Some but not all sidings fit.
Then I have a shorter length limit for the locals. It’s short of the siding limit, to allow for pickups and doing work at each stop.
Then there’s the narrowgauge lines. The ruling grade is more of a weight than length issue. I sometimes run two units in DPU and have 20+ car trains. It have to spread out the power to avoid stringlining on the 4%, 24" r curves with trains that long and everyone else takes the sidings, but makes it easy to catch up when traffic is heavy.
Otherwise, I have kept trains to about 12 cars total on the main line. My K-27 are only rated for about 6 cars. On the branches off it, the limit is around 6 cars and weight is the issue there, depending on the loco. The limits are reflected in the siding length pretty accurately, but I try not to crowd ever train to the limit, whatever it is. That really slows everything down.
Like Brent (Batman) I have a very long 2% grade. Mine curves back on itself about twice (36" radius), but I also have some large, heavy articulated steamers that can pull paint off of walls. But even with that, I usually limit my freights to about 15-20 cars. However, because of my mountain scenery with its ‘disguising’ cuts and tunnels, at no time can an entire train be viewed, so the impression is usually that of a much longer train. Passenger trains are usually about 8 cars. Occasionally I’ll run a 30 or 40 car train just for the fun of it, but not often.
Train lenghts are limited by the railroad (physical plant) not the power of the locomotives. Most trains out here are a mile long, because that is what they can put into the sidings. They have run 3 mile long trains with no problems, except of course they could not stop on the sidings. In the world of the Kangaroo they typically (or so I am told) run trains 3 miles in length.
In New York City, subway trains are limited to 10 cars (600 feet) because that is how long the platforms are.
On model railroad of LION this limit is 300’ (six 50’ cars) which calls for 4’ long platforms. This is long enough for people to get the idea that I am running a subway layout. Any longer, and I would just be wasting space. At 4’ I can get two platoforms on the 24’ wall, where as at six or seven feet, I could only place one and still have it look right.
One trick that you can do, is to use only brown colored box cars. That will make your trains look longer than they actually are. If you stick a bright yellow car in there, then the eye focusses on that as a point of reference. Without that the eye travels up and down the train looking for a place of rest.
On my home layout, passenger trains are limited to ~9 feet long, so roughly 8 cars and an engine. That’s the length of my passenger terminal tracks for the most part (some longer, some shorter). But I still model my trains prototypically. Instead of running the 14-car “Merchants Limited” or the 12-car “Yankee Clipper”, I run the 5-car “Commander” or the 8-car “Quaker”. There’s plenty of shorter passenger trains to pick from for a NH fan and still be 100% prototypical.
On freights, my trains are limited to ~12 feet long, which roughly translates to twenty 40’ cars w/ 2 engines. This is the length of my staging yard, and I really can’t exceed that or it messes up all other incoming/outgoing trains.
Now, over on my club layout during an operation session, the length is set by the terminal/yard track it’s going to or from. These can be anywhere from 16.5’ (2 engines, ~25 cars) to 26’ (3 engines, ~40 cars) for freights, and passenger trains can be 14 to 20 cars or more.
During an open house or train show, some trains never go into the terminal (they just park in a long siding). We have a fully loaded circus train that one member has (that is very popular with the public), and that train barely fits into our longest siding. That siding is 45 feet long. He runs during the show/open house with 6 Athearn Genesis SD70ACe’s, all on the head end. And his train is heavy due to all the metal circus wagons (the entire Walthers collection, AFAIK). For all that, it rarely derails. In fact, at the last show it ran for a total of 4 hours without any derailments.
Now, the longest train we’ve ever run for fun, however, has been 110 cars which we’ve done twice. One member has 110 matching Athearn RTR 50’ Bethgon coalporters in BN/BNSF, which translates to around 63’ long in HO scale…plus engines
As some have mentioned, the prototype usually has two governing factors:
Tonnage - What will a class of engine handle over a division.
Siding Length - Where can trains ‘fit’ while making a meet on a single track line.
On my layout, my sidings will hold 2 road engines, a caboose, and 12-13 40’ freight cars. The ‘big’ through freights are longer and any other train on the line has to be able to ‘fit’ in those sidings.
