The Ubiquitous Dockside Switcher
Interesting history piece on the B&O dockside switchers I just ran across
http://hotraincollector.com/the-little-engine-that-could-the-ubiquitous-dockside-switcher/
0-4-0 in Naval yard in Maine
Having been associated with the Navy in my past, I still get several publications of theirs. This photo of a small steam switcher attending a drydocked submarine in the 2020 Feb issue of the Naval Institute Proceedings caught my attention,…appears to be a ‘docksider’…
In the sense that it’s working alongside a dock… but that’s not the same loco.Cab is longer with no fuel bunker behind it, Boiler/water tank is much smaller diameter, among other noticeable differences with the C-16.
Brian,
I am curious as to what the caption said about the picture with the subs?
Here you go BigJim, hope it comes out OK
Perhaps in that colder climate up in Maine, they enclosed the fuel bunker within the extended cab?
Or it could be a fireless 0-4-0… The crew would fill the saddle tanks with steam from a boiler house or steam stand.
How about an alternative drive system arrangement for these docksiders,…motor and gears??
on another subject thread,…http://cs.trains.com/mrr/f/88/t/189515.aspx
I think this is indeed the case. Because if you zoom in close on the photo, you can see that the loco has a smokestack with smoke coming out of it, and the loco also has cylinders with side rods on the wheels. I think it’s probably an oil-burner with a bunker embeded in the rear cab wall.
That makes sense, since the navy started burning fuel oil, including what railroads called “Bunker C,” in its boilers in 1910.
Deano
