Timber Truss Bridge Abutment--Pictures Please
I need to design and build timber abutments for my truss bridge but haven’t been able to find any images to guide me. If anyone has some or can direct me, could you please post the images/info?
Selector–you posted an image of a timber abutment for a trestle 03/19/2011 in the thread "Bridge Abutments Lets See Them,’ but the link no longer works. Could you please post it again?
Here’s the environment, in case it might be relevant:
Thanks.
Rick Krall
Maybe this can help:
http://www.sceneryexpress.com/prodinfo.asp?number=KB12101
During the recent New England flood events one of the networks documented the loss of a historical covered bridge - which was, in fact, a timber truss. The roof and sidewalls are meant to keep the main timbers dry.
Pertinence? The abutments were masonry, built up of large blocks of cut stone. Of course, the bridge was in granite country, with quarries in the vicinity.
If you are still interested in an image of a typical abutment for a timber tresstle, here is how mine turned out. I note that there should be a single level of bent frame bolted up snug to the vertical face of the timber abutment. Or, so I have seen on other examples.
Crandell
Great input, thanks. Chuck–I’m modeling a PA shortline, so the stone abutment can make sense. I’ve looked at Chooch, but the step is too high for my bridge. I could build short piers, of course, but I don’t know if that would be prototypical with a stone abutment, even with some creative license. I do like the flexibility the piers would give me to trim and assure the bridge is level, though.
Crandall, that photo is perfect. The original thread I referenced contained your helpful construction tips, which I’ve retained and will follow if I go for a wooden abutment.
I wasn’t aware of the book but will definitely check it out.
Rick
You can also creat your own stone abutments out of pink foam.
On my N scale Mt. Coffin & Columbia River layout I sanded a block of foam, put a thin layer of lightweight spackle on the sides, and then carved the stones:
Paint with cheap-o grey craft paint, some washes from the “Big Jug O’ Stain”, and it turns out okie dokie:
The other side of the bridge / pier has a wood abutment (part of the wood bulwark around the riverside) but, funny thing, I’ve never taken a picture featuring just that.
Here’s the best views I can find:
Hope this helps.
Remember to have fun and don’t get “bent” out of shape over it :wink:
