TOGGLE SWITCH WIRING
Hi awesome fellows,
Does anyone know (or can lead me to) how I would wire the DC power supply to my Atlas tt motor?(Im using a Hornby SELECT controller power supply)
What I want to do is have a “MAINS” power switch (with a green LED for ON, and red for OFF) on my control panel, that I can turn on and off then have that main power switch connected to the TT motor control switch in which I would use a DPDT to change the motor direction,
Would this be practical? as when im not using the TT I can have it switched off at the MAIN toggle on-off switch?
Does anyone have something similar ?
Thanks in advance from the land “DOWN UNDER”
Content removed due to a completely fucked up and incompetent Kalmbach customer service.
not sure if you know how to do what you want and are asking if others have done same, or if your looking for a circuit.
svein describes the wiring of a reversing switch. See image below
you could also use a SPST switch to control power to either your TT switch and a green LED, or in the other position the red LED. You could also simply use a SPST switch to control power to a TT and an LED.
TT = Turn Table?
Are you simply trying to use the same controller for the turn table as you are for a train?
I am not familiar with Hornby at all. Is there something special about it.
Otherwise it just sounds like you want the turntable controls to have an additional on/off switch. The only complication there is the additional option of having a red LED when in the off position.
What am I not understanding?
The only way for you to accomplish what you want,is to have a relay switch to keep,either the green lite on ,or the red lite,you cannot do what you want with just a DPDT…You can have a pilot lite stay on if you put it,before the leads in Gregs,diagram,but only red or green,not both…So when you turn on the power switch,the lite will go on and you will have power to the DPDT toggle to control the TT. That is the only way you can have a lite on without a relay…
Cheers,
Frank
this is what I tried to explain above. You can use a SPDT switch to control power to the TT switch and LED, or to a 2nd LED
Do you need a red light for off? If the green light is off, it’s off. Much simpler.
Dear Zepher
The Hornby controller is one I got with a train set, but then after further research I ended up using the mighty NCE, so the Hornby doesn’t control any trains its just a spare I have lying around ,
There is definitely nothing special about Hornby!!
I will just use the power supply that came with it to power my TT (Turntable) motor that’s all as I don’t want to use my TT on DCC.
So how do I wire the power supply leads to a master ON_OFF switch then to another ON-OFF-ON switch
ON being for clockwise direction, the other ON for anticlockwise
Thinking I will ditch the LED idea as im just learning electronic side of railway modelling
ITS SOOOOOOO MUCH FUN
One thing I do want to do is have a separate power switch for each of the storage tracks in the round
house and on the storage tracks so when I start up the layout all the engines with sound wont come on until I command them to.
Is this just a case of wiring a SPDT switch on each of the tracks ?
And does the power for the switches come from the feeders to each of the required tracks?
Help needed here!!!
Yes,or even a SPST, as killing one side of the rail works just as well.
The short answer is it doesn’t mater where the track power comes from, ethier a close piece of mainline track or the power supply itself. However since the switches are usually closer to the power supply, it is easier to run a single wire from the track power supply directly to the switches and then from each switch a feeder to each track coming off of the turntable.
So what I suggest for the round house tracks.
  1. One side of track power supply to one side of all the SPST switches.
  2. From the other side of each SPST switch one wire to one rail of each corresponding round house track. 3. All the other rails of the round house tracks go to the other side of the track power supply.
This is a universal on-off scenario and works for DCC, DC, AC, Railcommand, or basically anything electrical.
Actually since you probably would ever only want 1 round house track on at any given time a selector switch might work well. Single pole times x positions where x is the number of round house tracks.
Tomcat,
The simplest,wiring,is in the diagram,that Greg,provided,just leave off,either the Red or Green lite…To make it even easier,leave out the LED’s and resistors and use a incandescent bulb. I have a feeling though, from your other Thread on the same subject,that you are not very familiar with a diagram,for a Electrical circuit,so therein lies a problem with trying to explain it to you…One thing I have to ask,what is the voltage requirement for the TT ?? 12 volts,16 volts,AC or DC and what is the output of the power source…You don’t want to have your TT take off like a rocket,every time you use it,by lowering the voltage to the motor,of the TT,you can slow the speed down. For instance: 12volt motor supplied with 12volts of power will turn fast,unless it has a gear reduction motor,even then it will run fast…Now if you just supplied 6volts to the 12volt motor,it will turn much slower and look more realistic…
Cheers,
Frank
Hi ZSTRIPE.
You know me so well!!! I do have trouble with diagrams unless it is very basic I sort of understand Gregs .
I need 12V DC for the TT motor and Ive just found out that the power supply I was to use is 16V AC!
Can I still use this 16VAC anyway. the controller also has a rheostat type knob on it so that can help with the speed of the turntable should it not ?
So Where do I go from here? A 6V supply ? Need your input here Frank!
instead of dealing with the above circuit, you could use an old unused model train transformer that has a rheostat and reverse switch connected directly to the TT. The reverse switch controls the direction and the rheostat the speed.
What happens if I use the one I have
16V AC the TT motor says it needs 12V DC ,? It has a directional switch on it as well as a rheostat knob?
Do I need to buy one that’s rated at 6 or 12 Amps for a more realistic movement of the table
Tomcat,
Don’t even try using that 16vac power supply for the 12volt motor,it may work for a while,but will eventually burn up the motor,plus,you wont be able to reverse the direction of the motor…Is there a variable DC Throttle,on that power pack? You could use that wired,to a simple,spst switch,on one leg of the wire,coming from the power pack and use the reversing switch on the power pack,to control the direction of the turntable.I f you do it that way,the throttle setting on the power pack,can control the speed of the turntable to your liking. When you are done setting your turntable alignment,just turn off that spst switch that you added. And when you want to reverse direction of the turntable,use the reversing switch on the power pack and then turn on the spst switch to change the position again,when set, turn off that spst. To totally shut off power,use the switch on your power pack…
The ideal scenario,would be to have a dedicated transformer,for power only to the Pilot lite and the dpdt,switch,like in Gregs diagram…Hope You understand,what I just tried to put in words…
Cheers,
Frank
strangely enough I do my friend! guess I must be learning something thanks to you and this forum!
I wont use that power supply, I will find the right one for the job . I don’t want to cut corners and make it hard for myself later.
If I remember correctly most laptop computers have similar power supplies for what I need, so I will search in the shed for one . if not ill have to plead my case to the bank manager (the wife) for a little cash for what I need.
My next thing is how do I wire - the power supply to a main power switch on my control panel of the layout (SPST)? -then from that main power switch to a switch that changes the direction of the TT motor (DPDT)?
you say the TT motor requires 12 V DC. AC won’t work.
if you have an old model train transformer with a rheostat, it should have a DC output that the rheostat controls. It may also have and AC output that you would not use.
I hope it’s clear that if you have a model train transformer with rheostat, you don’t need on on/off switch. The rheostat will reduce the output voltage to zero.
If you just want to just use some other DC supply, you would connect the negative or ground output of the supply to the ground on my diagram (the thing with 3 short horizontal lines on the bottom), and you would connect the positive side of the supply to the SPDT switch indicated by the triangle on the top left.
If you don’t use the LEDs, the polarity of the supply connections don’t matter because you have a reversing switch.
Tomcat,
I can’t post my own diagram,so I will use Greg’s,hope he don’t mind…
I don’t know how your control panel is going to be,so I’ll try to do this,best way I can. If you do get a Transformer,I would suggest at least a 1amp 6volt secondary output,there will be two leads at the primary,which is the AC side,will usually be black,the secondary side,usually have yellow,one positive,one negative,but that really doesn’t matter which is which now,you will have to get a line cord,with a plug at one end,so you can plug it in to your outlet. Now you will need a switch whatever you prefer,push button or toggle,on -off switch spst,rated at 3amp 120v,get a pilot lite color of your choosing,red ,green,amber and blue,rated the same,3amp 120v…Now you mount the transformer to the base of your control panel,one lead from your line cord gets connected to one of the black leads on the primary side of your transformer,along with a length of wire to go where your on off switch will be mounted on the panel,that wire goes to one off the wires on the pilot light…now the other line cord wire,goes to the on off switch that is mounted on your control panel on one terminal of the switch,the one lead left on the pilot light goes to the other terminal on the switch,along with a length of wire,to go back to the remaining black wire on the primary si
Tomcat,
I didn’t mention this in my other post,but if you want to put a three way plug for the line cord,the white wire is the first wire that you would put on the primary side of the transformer,the black wire goes to the switch,the green wire goes to one of the mounting screw holes on the transformer base. And if you want to be even safer,put a in line fuse 1amp 120v,on the black wire from the switch wire that goes back to the transformer wire. You could do the same for one wire that goes to the toggle switch for the turn table, a 1/2 amp 12v fuse.[:D]
Cheers,[D]
Frank
are you sure you want to build your own power supply? 120V can hurt
here’s a basic schematic i found on the web
